Drivers for the Palit GeForce GTX 1050 ti dual OC 4gb graphics card
kacperno 11067 8
  • #1 16175102
    kacperno
    Rate: 10
    I assembled a computer with new components:
    The H110M S2H DDR3 motherboard
    The first drivers were installed from the motherboard. I have a problem with installing drivers from the graphics card. When attempting to install it crashes the error.
    I have installed Windows 10 64 bit and drivers were downloaded from various sources under this Windows; on each one crashes the same error.
  • #4 16175227
    kacperno
    Rate: 10
    Yes, I downloaded it from the producer, I even installed it from the motherboard provided with the graphics card from the nvidia.com website, I also downloaded it. Is it possible with windows 10?
    This update in windows update also came to me
    nVidia - Graphics Adapter WDDM1.1, Graphics Adapter WDDM1.2, Graphics Adapter WDDM1.3, Graphics Adapter WDDM2.0 - NVIDIA GeForce GTX 1050 Ti.
    Error
  • #5 16175368
    Rafik_ck
    Help: 19
    Rate: 84
    It is not possible that you can not install the drivers under your card
    A step-by-step demonstration of how you choose the driver for your graphics and for your system. Something bad you do. You can install under the GTX 1050 and not under the GTX 1050Ti.
  • #6 16175386
    kacperno
    Rate: 10
    I installed GeForce Experience and search for graphics drivers, found, downloaded, and wanted to install, the same error pops up
  • #7 16175387
    Kasek21
    Help: 4981
    Rate: 3547
    Rafik_ck wrote:
    Maybe you are installing under the GTX 1050 and not under the GTX 1050Ti.
    After all, it's the same driver!
    What does the Device Manager look like?
    What about the re-installation?
  • #8 16175405
    Rafik_ck
    Help: 19
    Rate: 84
    Apparently the driver is the same but he is not the same.
    In Nvidia, it's 1050 and 1050Ti apart and it's everywhere.
    And if it would be a driver for only one 1050 card, it would not be 1050Ti drivers, only generally 1050 there is something for this.
  • #9 16176184
    kacperno
    Rate: 10
    I do not know how the miracle but everything worked backed windows and left the computer turned on to do all the windows updates and the driver that I earlier hung now installed without a problem after all I could normally install drivers from NVIDIA
The discussion revolves around issues faced while installing drivers for the Palit GeForce GTX 1050 Ti Dual OC 4GB graphics card on a system with an H110M S2H DDR3 motherboard running Windows 10 64-bit. The user encountered installation errors despite downloading drivers from various sources, including the manufacturer's website and NVIDIA. Responses suggest ensuring the correct driver version is selected, as there are distinctions between drivers for the GTX 1050 and GTX 1050 Ti. After troubleshooting, the user resolved the issue by restoring Windows and allowing all updates, which enabled successful driver installation.
