[Solved] Trouble Installing Nvidia Geforce GTX 1050TI Gaming X Drivers on Win10 PRO 64bit
Wimp 23619 7
  • #1 17589208
    Wimp
    Rate: 9
    Hello, as in the title, I got an SSD yesterday, I decided to put it in the computer right away, everything is fine, I formatted older disks, and installed Windows 10 Pro 64bit, and here is the problem. Namely, the problem with installing drivers for the Graphics Card, the exact model is: Nvidia Geforce GTX 1050TI Gaming X from MSI (4gb version), when I turn on the latest drivers for the Graphics Card, after the expectations, I get an error about "No compatibility with this version Windows ". I can't install them via the Manager either.
    I am asking for quick help, thank you in advance and best regards :)
  • #3 17589216
    Wimp
    Rate: 9
    Yes for the 64 bit version of the System
  • #5 17589241
    Wimp
    Rate: 9
    Thank you Methuselah, but I will try to download the latest drivers from Pitera College first, when it does not work, I will try the way that is shown on that page, thank you in advance for all help and best regards :)
    Added after 6 [minutes]:
    I downloaded the drivers from the MSI website, but the same error occurs: /
  • #6 17591100
    beatamycha
    Help: 32
    Rate: 55
    Is your Windows system up-to-date? Please update if not.
  • #7 17591391
    Myrasz
    Help: 10
    Rate: 82
    I also had such a problem with the GTX1060 6GB card. I have installed GeForce Experience and with this tool I installed the drivers. During installation, I recommend that you uncheck everything except nVidia Physx (the driver cannot be unchecked).
  • #8 17700704
    Wimp
    Rate: 9
    Updating the system helped.
The user encountered issues installing drivers for the Nvidia Geforce GTX 1050TI Gaming X graphics card on a newly installed Windows 10 Pro 64-bit system. Despite downloading the correct 64-bit drivers, an error indicating "No compatibility with this version Windows" occurred. Suggestions included ensuring the Windows system is up-to-date and using GeForce Experience for driver installation, with a recommendation to uncheck all options except Nvidia PhysX during installation. The user later confirmed that updating the Windows system resolved the installation issue.
