Honda Civic VII 1.4 16v, 66kW, HB 5D, 2001. poor interior heating.
Jesionki 12072 7
  • Poor heating and unresponsive temperature control diagnosis request
    #1 16176851
    Jesionki
    Rate: 60
    I was looking everywhere, but unfortunately did not find a solution.
    Problem:
    Honda Civic VII 1.4, heats poorly regardless of the position of the "heat / cold" knob. All control cables are in place, the bulkhead valve responds to the cable. Coolant level normal. It heats better in closed air circulation, but unfortunately everything evaporates even in the climate. It is known that in a closed circulation system, air is always warm, taken from the car, heated, so maybe for this, but what can be the cause of poor heating and lack of response to air temperature regulation? It is also strange that as the control knob turns the cold one, it is also unchanged. I suspect an airflow control system, but how do you check it?
    Perhaps someone had such a case and dealt with it?
  • #2 16177644
    Piasek80
    Help: 129
    Rate: 666
    The control of the heater's flaps may be damaged, or maybe the classic heater to be replaced.
  • #3 16179041
    Jesionki
    Rate: 60
    Can you elaborate on the topic? Any particulars? I will be very grateful...
  • #4 16179068
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    First of all, are the engine temperature readings normal?
  • #5 16179306
    Piasek80
    Help: 129
    Rate: 666
    Of course, I take for granted what the speaker asks about, i.e. that the most obvious obviousness (read: thermostat) works properly, because that is where the discussion should start.
    So it works? Does it catch operating temperature quickly?
    It's gasoline, therefore, no problem, even in frosts like this morning, in my case -13 * C, it should catch 70 * C after the first three kilometers of driving.
  • #6 16179307
    Jesionki
    Rate: 60
    Yes, sorry I didn't refer to the cooling system. Display and engine temperature and its heating OK.
  • #7 16179350
    Piasek80
    Help: 129
    Rate: 666
    I do not know if there is a thermostat regulating the water temperature for the heater (because you are squeaking something about one) or a classic flap closing the air supply from the outside:
    - if it's the first - then you have to check with your hand on a hot engine whether the hose behind it is as warm as in front of it
    - hereafter this hatch - can be jammed in the open and packs masses of cold air
    - the worst option: the heating system is dirty - these are small sections, years of unchanged fluid, mixing anything, or applying some sealant in the cooling system and after heating ...
    Sometimes rinsing helps, but in most cases it is necessary to replace the heater with a new one, which costs little in relation to the cost of the replacement itself because only in a few cars it can be replaced without disassembling the entire cockpit.
  • #8 16179388
    Jesionki
    Rate: 60
    Piasek80, I am grateful to you for your willingness and valuable comments, but I would rather ask for advice on this particular vehicle, not a lecture on the theory of vehicle construction :D What you write are timeless truths ...
    Maybe some help in checking the operation of the air stream blades in the heater unit (how to check if they are working properly), or other substantive advice that would solve the problem.
    There is a lot of advice on all topics, but not solving the problem and not very substantive. Maybe we can create a helpful pill here? :spoko:
The discussion revolves around the poor interior heating issue in a 2001 Honda Civic VII 1.4 16v. The user reports that the heating system does not respond to the temperature control knob, with better heating observed only in closed air circulation. Responses suggest checking the heater's flap control, thermostat functionality, and potential blockages or dirt in the heating system. The importance of verifying the engine's operating temperature and the condition of the coolant is emphasized. Suggestions include inspecting the air stream blades and considering the replacement of the heater if necessary.
