Modecom FreePC Minicomputer: Restoring Original System Settings after Power Cut, Error 0xc000000f
rkoziol7 4668 1
  • Recovering Windows after interrupted reset and 0xc000000f
    #1 16177058
    rkoziol7
    Some time ago I bought a Modecom FreePC minicomputer with Windows 8 on board. After some time, I upgraded it to Windows 10.
    Today I decided to restore the original system settings using the standard "Windows recovery tool". I've done this before and everything was fine, but today it turned out that I had a short-term power cut during this operation. And the ride began. The computer, of course, turned off, and after turning it on, the operating system does not load and displays the error:
    "Your PC / Device needs to be repaired. The operating system couldn't be loaded because a critical system driver is missing or contains errors.
    File: \ WINDOWS \ system32 \ drivers \ iorate.sys
    Error code: 0xc000000f "
    I admit that I do not know what to do in this situation. Of course, I don't have any system CD or USB for my razor as it has a pre-installed system. Is there any chance of its recovery? The device warranty just expired on January 3.
    New Year greetings
  • #2 16181354
    ruskm
    Rate: 25
    Windows Creation tool - will allow you to create a botable pendrive with Windows 10 installation - you do not need the key because it will not call you
    Install the system as on a normal PC.
    On the tablet that also had originally 8 updated to 10 helped. (also broke down when trying to restore)
