[Solved] Volkswagen Touran 2012 1.6TDI - firing dpf auto in safe mode VCDS
wyginty 21525 11
  • #1 16427779
    wyginty
    Rate: 33
    Hello. After the diesel particulate filter is lit, the car has gone into emergency mode. What is the dpf burn-in procedure in 1.6tdi Touring from 2012 CR engine CAYC designation. I will add that I have to force forced afterwards.
    Maybe someone from my friends will help. I've tried but can not make it. greetings
  • #3 16427839
    adam7009
    Help: 656
    Rate: 1631
    in emergency mode can prevent the procedure for safety reasons, it may be too late to burn.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #4 16427874
    sadek1979
    Cars specialist
    Help: 237
    Rate: 1418
    If any system is not functional, the procedure may not start.
  • #5 16438188
    wyginty
    Rate: 33
    I have started the vcds procedure only in measuring blocks instead of falling soot is growing. Does it have to take or do something wrong?
  • #6 16438685
    miler80
    Help: 272
    Rate: 1392
    Odis leads the handle and does it until the end of the process, or about 1 hour. Check the oil level, whether the condition is exceeded, check whether the turbo does not let it into the system.
  • #7 16438770
    wyginty
    Rate: 33
    Unfortunately, I do not have Odis. I have what I have or vcds and I would like to deal with this.
    I noticed that when I started the firing procedure, after some time I started to display the message "oil pressure drop - switch off the engine". Maybe this is because of it
  • #8 16438969
    miler80
    Help: 272
    Rate: 1392
    If it did not break the procedure, the engine would end its life.
  • #9 16439029
    szymitsu21
    Help: 342
    Rate: 1292
    Oil is not uncommon like water? by ON in oil ..
  • #10 16439121
    wyginty
    Rate: 33
    What does the oil replace ???
  • #11 16439479
    adam7009
    Help: 656
    Rate: 1631
    Do you want to do it and work the next 200 thousand, or to play alone?
    if it's the first one, talk to PW.
  • #12 17121448
    wyginty
    Rate: 33
    I did this: As if replacing dpf with a new one, then the car unlocked from the emergency mode, then burning dpf at a standstill, until it dropped to the appropriate value, the car flashes like new.
✨ The discussion revolves around the procedure for burning the diesel particulate filter (DPF) in a 2012 Volkswagen Touran 1.6 TDI with a CAYC engine designation, which has entered emergency mode due to a lit DPF warning. Users share insights on the challenges faced during the DPF regeneration process, including the necessity of using VCDS for forced regeneration and the potential complications if the engine systems are not functioning properly. Some participants suggest checking oil levels and turbo functionality, while others recommend consulting professionals if the DPF replacement is needed. One user successfully unlocked the emergency mode by replacing the DPF and performing a stationary burn until soot levels decreased.
