Renault Master 2.5 dci: Replacing Damaged Fuel Pump with Hand Pump - Will it Work?
M-A-T-E-U-S-Z 23619 11
Can I use a hand primer bulb to replace the failed in-tank fuel pump on a 2002 Renault Master 2.5 dCi so the engine will start?
A hand primer bulb should not be treated as a replacement for the fuel pump; it is primarily intended for bleeding the fuel system and may not provide the required fuel delivery [#16178427] The 2002 Master II 2.5 dCi 115 hp is reported to have a low-pressure pump in the fuel tank, so first check whether the pump is being controlled [#16179027] Trace the pump wiring, and if necessary remove the tank and replace the pump [#21293573] Also inspect the fuel filter and check for air leaks, especially around the filter and injector return lines, since a leak can aerate the system and prevent starting [#16178823][#16178917]
  • #1 16178363
    M-A-T-E-U-S-Z
    Rate: 57
    I have a problem with the fuel pump in the tank. It probably burned up and, unfortunately, it does not burn fuel to the filter, which results in the inability to start the engine. I thought to install a hand pump for now - a pear, but I do not know if it will give the desired effect and the engine will start. I am asking for more informed opinions.
  • #2 16178427
    19710128
    Help: 5
    Rate: 40
    Rather, you do not inflate fuel so much. This pump is for bleeding.
  • #3 16178721
    pp_pablo
    Help: 93
    Rate: 405
    Buddy and who installed it there because it's not Renault? There is no pump in the tank in the master, who told you such stupid things?
    Enter the year of the car and how many KM it has.
  • #4 16178823
    AniolBosch
    Just as a colleague writes, these renault do not have an electric pump in the tank but an initial pump on high pressure and possibly rubber pear. Most likely, you have a leaky system, most often it is aerated around the fuel filter and on the return from the injectors.
  • #5 16178864
    M-A-T-E-U-S-Z
    Rate: 57
    I will not argue because I do not know if there is a pump or not, but the strange thing is that before I turned the key, you could hear something like a pump and you could see on the fuel hose that this fuel flows clearly towards the filter. Now when there is more frost, unfortunately after turning the key does not have this characteristic buzzing and no fuel flows towards the filter which results in the inability to fire. Engine 2.5 dci 115km year 2002
  • #6 16178917
    pp_pablo
    Help: 93
    Rate: 405
    In what state of the fuel filter?
  • #7 16179027
    moto-kord
    Help: 137
    Rate: 505
    Renault Master II generation with a 2.5dci 84kw / 115km engine has a low-pressure pump
    in the fuel tank. Check whether the pump is controlled.
  • #8 21292684
    miniblack
    Hi, I'm linking to the topic, is the control of the fuel pump in the tank via some kind of fuse/relay? Greetings and thanks for any answers
  • #9 21293573
    robsongostynin
    Before 2003 they had a pump in the tank. Trace the wiring and see if it works, but you'll probably have to remove the tank and replace the pump.
  • #10 21293611
    miniblack
    Whoa, mother and daughter, that's a build up. I'll probably be lying under the master on Sunday instead of under a palm tree in the tropics. Thanks, greetings.
  • #11 21330926
    zachary28
    Have you managed to trace anything? Is there a pump in the tank or a high pressure pump to dump?
  • #12 21558214
    sunhouse
    Rate: 12
    So the boy lay under the car , that the topic died ....
The discussion concerns a Renault Master 2.5 dCi (115 hp, year 2002) experiencing fuel delivery failure due to a suspected burned fuel pump in the tank, resulting in no fuel reaching the filter and engine start failure. It is clarified that this model typically has a low-pressure electric fuel pump located in the tank, controlled by a relay or fuse, which should be checked. Some users note that earlier Renault Masters (pre-2003) do have an in-tank pump, while others mention the presence of an initial high-pressure pump and possibly a manual rubber primer pump ("pear"). The problem may also involve air leaks in the fuel system, especially around the fuel filter and injector return lines, causing aeration and fuel delivery issues. The original poster observed a loss of the characteristic fuel pump sound and visible fuel flow in cold conditions, indicating pump or electrical failure. Suggestions include verifying the fuel filter condition, tracing wiring to the pump, checking pump control circuits, and potentially removing the tank to replace the pump. The idea of temporarily using a manual hand pump ("pear") to supply fuel was questioned, as it is primarily intended for bleeding and unlikely to provide sufficient fuel pressure for engine start.
