Master III 2013: Installation Scheme, Error P087, Low Pressure, Injection Error, Fuel Pump
jarek1 35322 14
Where is the fuel pump in a 2013 Renault Master III powered from, and what can cause low-pressure/injection faults when the pump in the tank is not running?
The fuel pump is fed through relay R1 and fuse No. 10 (20A), and it should run after the ignition is turned on, usually for about a minute [#16339188][#16340018] The most likely fault in this thread is a burnt pump connector/pin at the tank, which can stop the pump from working and is described as a common factory defect [#16339130][#16343302][#16339676] So the first checks are the pump plug and wiring at the tank, then the supply at the connector, rather than assuming the pump itself has failed [#16339188][#16343302] If the connector/pin is damaged, the practical fix used here was to replace or resolder the plug/wires and insulate the joint well [#16343302]
  • #1 16338921
    jarek1
    Help: 38
    Rate: 47
    I have a question for my colleagues, maybe someone has an installation scheme for Master III from 2013. The problem with the car is that while driving showed an error in the injection and there was error P087 low pressure on the beam the car returned on the trailer after erasing the error, the car fired 6km and again stands . Now it does not fire or show any error what I noticed that I can not hear the fuel pump in the tank now I do not know if it turned on after every key turn or not. I've broken the fuel line from the fuel filter and the pump does not pump and I think that this may be the reason for the failure. My question now, where the fuel pump in the tank is fed from, I will try to measure on the bundles only I do not know where to look and pulling the tank with 80 liters of fuel is an average pleasure.
  • #2 16338944
    piotrekwoj1
    Help: 947
    Rate: 3433
    The pump may only be switched on during filming. Bury yourself with the plug from the pump, put on the tube and turn off. When the pump is lit it will not look like it.
  • #3 16339002
    moto-kord
    Help: 137
    Rate: 505
    You can give the power of the car how many kw and you can know the engine code
  • #4 16339075
    jarek1
    Help: 38
    Rate: 47
    2,3 125 HPM engine.
    When it comes to checking the pump at the ankle, I have to take the tank from the car and I have about 80l of fuel. I thought to hook up to the computer and give 12V to the pump.
  • #5 16339130
    MobilTruck
    Help: 139
    Rate: 965
    The pump in these cars starts after turning the ignition.
    A burned pin in the plug. The tank is enough to unscrew the two clamps, the third one to let go only.
    It's already some master with this defect, it turns out that the factory defect.
  • #6 16339188
    moto-kord
    Help: 137
    Rate: 505
    Relay R1 controls the injection system, fuse No..10 -20A fuel pump.
  • #7 16339676
    genek1000
    Help: 289
    Rate: 1057
    pitool wrote:
    A burnished pin in the plug
    I completely agree . Poor quality material on the pins in the pump connector.
  • #8 16339813
    jarek1
    Help: 38
    Rate: 47
    Thank you and help tomorrow I will draw the tank and check, let me know about the effects. One more question how to vent the fuel system after removing the hose from the fuel filter system has been blown.
  • #9 16340018
    MobilTruck
    Help: 139
    Rate: 965
    You turn on the ignition and wait, the pump will work a good minute and that's enough for him.
  • #10 16343302
    jarek1
    Help: 38
    Rate: 47
    Hello again, it turned out that the socket in the fuel pump is burnt out. I still have a question where you can get a plug that is on the beam because the connector in the pump burns out and additionally in the beam.
  • #11 18990249
    waldee
    I refresh the topic
    A year ago, I was touched by the standard problem of a burnt fuel pump socket. The plug is also stoned on one pin. I replaced the pump with the plug. A year has passed and the pump has stopped working / feeding fuel again. After removing the cube on the pump, it turned out that the same pin in the plug was burnt. Slightly yellow plastic around the pin in the pump. I soldered the plug, but when I pressed it into the pump socket, I cannot push it all the way in so that it locks. There is a yellow cap and a rubber gasket on the plug. Can this plastic cap be removed so that the plug comes to the end in the pump socket?
    What could be the cause of such a cyclic failure? Is there a problem with weight or is the voltage applied to the pump incorrect? Where to look for the cause? I don't care about replacing the fuel pump every fall ...
    A crazy idea came to my mind ... How to connect a 12v in-line pump between the tank and the fuel filter and disconnect the factory pump in the tank (or when the socket gets hot again). Such a modification has the right to work?
    Thanks for your interest in the topic
    waldee
  • #12 18990436
    michal_rybka
    Help: 283
    Rate: 771
    solder thick wires to this pump mounting on the tank permanently and pour silicone (preferably Reinz) and solder to the original cables and nothing will burn out
    this pump in the tank runs on the key all the time - a friend once filled up a whole tank of gasoline and he dripped off when he went to pay, and I disconnected the fuel hose from the filter and extended it and let everything go to the bubbles, I thought that we would have to dismantle and hold a relay, but it turned out that this pump is still running when the ignition key is turned on - strange, but it is
    it also vented the air, poured oil and fired normally
  • #13 18990689
    waldee
    thanks buddy for a great idea. In order for the whole to be disassembled, I will solder the wires terminated with a 4 PIN socket to the pins in the pump socket and connect this socket with the plug from the car installation side. On the net I found a Superseal 4PIN hermetic connector with wires for PLN 7.35 and yesterday I gave PLN 70 for the plug to the pump. Shops have felt the pinch and are charging like gold. If after a while it turns out that the cube-plug connection burns up, the car will go to "Jew" ;)
    waldee
    PS when I solder all this, I will send a photo for posterity.
  • #14 19365960
    Talosny
    Already a third pump to be replaced! For colleagues who say that the tank is not! Has! Pumps! I say it is because I have already taken it out twice! This is probably a factory defect!
  • Soldered pump pins and wiring to fix failure
    #15 19366015
    waldee
    In October, after diagnosing that one of the pins in the pump burned up again, I did as I wrote 2 posts above. I removed the pump from the tank, cut off the top of the socket to access the pump pins
    I soldered the wires with the socket to the pins. From the side of the car's electrical installation, I soldered the wires ended with a plug. I insulated the soldering point on the pump with Reinz and the wires from the installation side with heat-shrinkable sleeves.
    It's been half a year now and knock on the door, the car works without any problems
    Waldee
The discussion revolves around a 2013 Master III vehicle experiencing injection errors and a P087 low pressure code. The user reports that the car fails to start and suspects a malfunctioning fuel pump, as it does not activate when the ignition is turned on. Various contributors suggest checking the fuel pump's power supply, inspecting the connector for burnt pins, and the possibility of a factory defect. Solutions include applying 12V directly to the pump for testing, replacing burnt connectors, and venting the fuel system after maintenance. The conversation highlights recurring issues with the fuel pump and connector integrity, with some users sharing successful repair methods.
