Opel Vectra C 2004 1.8 122HP - Cold Engine Misfire and Unresponsive Gas Pedal Issues
winters8903 11064 14
What can cause a cold-engine misfire and loss of throttle response in a 2004 Opel Vectra C 1.8, especially when the car is on LPG?
The most likely cause is the LPG system itself—especially the gas temperature sensor, gas nozzles/injectors, LPG ECU map, or corroded LPG-control connections—rather than the new coil or plugs [#18370595][#16180866][#16180595] One user reported that replacing the temperature sensor in the gas installation fixed a very similar fault, and another found that the LPG had corrupted the controller map [#18370595][#16180866] It is worth checking the LPG wiring and control unit contacts, and visiting a competent gas installer because a bad bypass/cut wiring can also cause misfires through the petrol injection path [#16180595] To isolate the fault, run the car on petrol only with the LPG cylinder valve closed and see whether the problem disappears [#16180177] If it still misfires, also check valve clearances/unsupported valves, compression, and possible burned valves or intake/head gasket leaks [#16181476][#16179876]
  • #1 16179745
    winters8903
    Hello. I have an Opel Vectra C engine 1.8 122KM from 2004. I have been struggling with the problem for a year, namely that the cold engine when the car is after a night or is standing for about a few hours after starting the engine can strangle it automatically and the engine goes out. When driving about 500m, it can jerk it and it does not react to the gas pedal. Sometimes, not always when something like this happens, the chack pops up, after peaking the same error misfiring on the 1st or 1st and 3rd cylinder. Today, when there were frosts of -26C, I had a problem with firing up, what the engine started, it immediately choked it and it went out and the misfire error popped up. After several long continuous firing, after about 10 minutes it started to walk and did not go out. I replaced the candles and the coil. Nothing helped. What could it be? I will add that the car is on gas. The dampers were also replaced. The coil is new, original and even transferred from the second car. Same thing unchanged.
  • #2 16179876
    A.Gieronimo
    Help: 268
    Rate: 309
    Everything can be.
    Chinese coil.
    Burned valves.
    Gaskets at the manifold or under the head.
    This problem is quite known in this model.
    You can start with the electrics, treat the plugs / connectors, ECU, injectors, etc. with a suitable spray, it is only PLN 10 ;) and then you will add one zero to the price list and then another ;) . Happy New Year.
  • #3 16179968
    jack200
    Help: 6
    Rate: 85
    You replaced the coil and candles, and did you remember about high-voltage cables? I had a similar problem with a lanos with an oploskim engine, the cables were to blame, after replacing everything returned to normal, fire it on a cold one in complete darkness :D and look at the wires for sparks.
    Moderated By CameR:
    jack200 wrote:
    and did you remember about high voltage cables?
    ... have you ever seen an engine in a newer Opel?
    Reg. 3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #4 16180106
    winters8903
    Most Opel cars have not had high voltage cables since 1998. The coil lies directly on the engine and touches the candles with the so-called tits.
  • #5 16180177
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Poorly adjusted LPG can also be a problem, but there should be errors related to the mixture.
    It is worth checking the pressure on the pistons and driving a bit on the PB itself with the valve on the cylinder turned off.
  • #6 16180188
    oktawian89
    Help: 52
    Rate: 444
    And here, by any chance, the valve clearances are not adjusted?
  • #7 16180323
    winters8903
    As for the valve clearance, I do not know. Regarding gas, it may have something to do with how it happens on a cold engine, i.e. when the car runs on gas.
  • #8 16180595
    A.Gieronimo
    Help: 268
    Rate: 309
    The tarnished contacts of the LPG control unit are enough, the Pb injection bypass flows through it and there will also be a misfire. Added to this is the fact that, after all, someone has already cut these bundles to make gas bypass.
    Maybe at the beginning it would be appropriate to visit the gazownik ??
  • #9 16180710
    winters8903
    I was at 2 gas workers and they found no irregularities. It all looks more like an impression from a sphere.
  • #10 16180830
    A.Gieronimo
    Help: 268
    Rate: 309
    You need to short the Pb injectors and stop reading coffee grounds, the LPG ECU may be damaged and no reading will help.
  • #11 16180866
    moto-kord
    Help: 137
    Rate: 505
    Hello, I fought such a vectra (Z 18 XE) last week, except that apart from falling out
    ignition, there was also a lambda probe error, it turned out that the gas smashed the map in the controller
    The driver, the regenerated car, flashes.
  • #12 16181476
    milejow
    Help: 1563
    Rate: 5148
    This is what regulates itself, but it is not easy because of the height of the glasses.
    Cover up and check to see if any is unsupported.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #13 18370533
    kuczrob
    Say what you mean by driver regenerated?
  • #14 18370595
    winters8903
    I will add that I dealt with it a long time ago. It turned out that I found a gas nozzle and it was enough to replace the temperature sensor in the gas installation. Other bunglers came up with all sorts of theories from outer space.
  • #15 18370610
    kuczrob
    So you did not interfere with the engine computer?
The discussion revolves around a 2004 Opel Vectra C with a 1.8L 122HP engine experiencing cold engine misfires and unresponsive gas pedal issues. The owner reports that the engine stalls after starting, particularly in cold conditions, and occasionally displays a misfire error related to the first and third cylinders. Despite replacing the spark plugs and ignition coil, the problem persists. Suggestions from forum members include checking high-voltage cables, adjusting LPG settings, inspecting valve clearances, and examining the LPG control unit for tarnished contacts. Some users also mention potential issues with the engine's ECU and the lambda probe, indicating that the gas system may be affecting the engine's performance. The owner has consulted gas specialists without finding a solution, leading to further speculation about the root cause of the misfire.
