Opel Vectra C P0301 Misfire: Z22SE LPG Engine, Ignition Loss, Cylinder 1 - Error & Solutions
Pangenitor 17091 5
  • Misfire occurs only on gasoline after cold start
    #1 16829751
    Pangenitor
    Rate: 16
    Here's another problem I'm struggling with. Ignition loss on 1 cylinder. Z22SE + LPG engine.
    I have already replaced candles and no improvement.
    The situation is so that the error occurs sporadically (once a week sometimes two) about 30 seconds after starting the car in the morning.
    When I delete it immediately, it pops up again after a week, sometimes two.
    It doesn't pop up on gas at all, or at least it hasn't happened yet.
    Specially I went only on gasoline, from one mistake to another for almost 2 weeks.
  • #2 16830314
    golfik-81
    if the only problem is on gasoline, it is suggested to check the gasoline injector, in some cases, if the error passes with the injection, you have a solution, if not, then checking the installation can be done with gas assembly, something went wrong
  • #3 16830359
    Pangenitor
    Rate: 16
    The gas installation is out, because I have it for 7 years, and it has never been before. This morning it popped out, I deleted it immediately. Today I did about 50km on gasoline, the car started and extinguished several times and again zero errors. At the same time stood about 9 hours not moved from the morning, so probably at 5 degrees outside it cooled down as after the night.
  • #4 16831334
    golfik-81
    it is really hard to rule out an ignition coil, in the morning when you start it, it starts on gasoline, unless in emergency mode you would start it on gas, but at these outside temperatures it is a pity for the evaporator
  • #5 16831969
    migmig85
    Help: 85
    Rate: 337
    Colleague Golfik-81 writes well first the injection change later the candle and the best compression measurement on the occasion of twisted candles and how it will not help you have to think further :)
  • #6 16884056
    Pangenitor
    Rate: 16
    The topic to close was caused by a damaged gasoline injector.
