Z-Wave Linux Setup for Logotherm Heating: Best Software for AURATRON 2025RTH Integration?
sealek 4677 5
  • #1 16182353
    sealek
    In the building where I live, the flats are equipped with 'residential heat exchangers', so called 'logotherms' - this has a valve like the one on the radiator so that the heating of the whole flat can be controlled - closing this valve cuts off the supply of hot heating water to the radiators and opening it causes the radiators to heat up.
    A valve with a thermoelectric head is installed which is controlled by the AURATRON 2025RTH controller - I can programme the heating in it and it controls it - somehow it works.
    However, I would like to make a solution available for configuration and control from the internet - I am considering a kit:
    Controller: Z-Wave Z-Stick Gen5 ZW090
    Switch: TZ76 to control the thermoelectric head
    Temperature sensor: ST814
    All components are z-wave, unfortunately I haven't had to deal with this technology yet. I have extensive experience with Linux, and it is on Linux that I would like to make myself this solution.
    Can anyone suggest what software is best to do this with? Maybe there is a ready-made system? Or maybe I can write one myself, just how to organise communication with the devices via the controller?
    Ultimately, I would like to expand the system later on - another idea is to use a TZ76 switch to control the DHW circulation pump and find an outdoor temperature sensor also with z-wave.
  • #2 16185025
    Zdzicho
    Help: 77
    Rate: 71
    How about DOMOTICZ ? After all, the AURATRON 2025RTH panel only sends ON/OFF information to the actuator , this can be scanned (868Mhz) and controlled by a plugin from Domoticz.
  • #3 16185086
    sealek
    This system caught my eye yesterday - and I think I'm going to give it a try - the question is whether it will work with the devices I listed :)
    Zdzicho wrote:
    And maybe DOMOTIC ?
  • #4 16282564
    Dorri77
    I am also considering Domoticz. Raspberry i already have :)
    Wants to connect it with some arduino based nodes (Pro Mini). Communication via nrf24l01+
    I just don't know if I'll be able to grasp it
  • #5 16293877
    sealek
    Zdzicho: and how do you scan what signal it sends? Also, I have the impression that not only does it go on-off but also some control packets in addition to the normal on/off operation of the system.
  • #6 16432740
    Martzz
    Danfoss Link also works in Z-wave transmission, I have had some experience with it and can recommend it
