Astra H Daytime Running Lights Installation: Connecting to Ignition Switch, Ground & Parking Bulb
bobo 44 7578 14
How do I wire daytime running lights on an Astra H so they switch off correctly when the parking lights are turned on, especially when the engine is running?
Use an additional relay instead of connecting the DRL control directly to the parking-light bulb wire, because the car’s bulb/voltage monitoring can leave only about 3.5 V there and cause flashing or failure to switch off when the engine is running [#16182905][#16183744][#16185257] Wire the relay coil with one side to ignition + and the other side to the parking/position-light supply wire; when the parking lights are switched on, both sides of the coil see +12 V and the relay drops out, cutting power to the daytime running lights [#16183813] This wiring was reported to work on several Opel cars [#16183691] If the problem seems tied to engine-running voltage rather than the parking lights themselves, try moving the control wire to a dipped-beam bulb to see whether the behaviour changes [#16185101]
  • #1 16182564
    bobo 44
    Help: 28
    Rate: 196
    Hello, I have to install daytime running lights and I bought the ones that fit the fog lights / which were not there / the problem is as follows I connected +12 for the ignition switch and minus ground, the cable switching to the cable from the parking bulb, i.e. we turn on the light, the daytime running light goes out and everything runs dry, i.e. without the engine running, if only the engine is started, the daytime running lights do not want to go out after the parking spaces are turned on, on the contrary, they flash somehow strangely after the engine is turned off, everything returns to normal or does it work or someone has a wiring diagram where I could plug in.
    best regards
  • #2 16182905
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    You need to use an additional relay so that the parking lights control this relay.
  • #3 16183645
    bobo 44
    Help: 28
    Rate: 196
    After all, the parking lights control these lights without the engine running after turning on the ignition, the problem is after turning on the engine.
  • #4 16183691
    frankrom
    Level 19  
    Help: 23
    Rate: 151
    I can read and understand the problem is after starting the engine. I made a dozen of these Opel cars this way and they all work as they should.
  • #5 16183744
    bobo 44
    Help: 28
    Rate: 196
    I have already done the connection of the relay coil to the position lights and this relay does not work because the voltage drops to about 3.5v, I will note that this relay takes a small current on the coil supply
  • #6 16183813
    jaga134
    Help: 88
    Rate: 192
    The relay coil is to be connected in such a way that you give the power to the ignition switch and the other end of the coil is to be connected to the power supply wire of the position lights. Then, after turning on the position lights, the power supply plus appears on both ends of the relay coil and the relay disconnects the power supply to the daytime running lights.
  • #7 16184701
    bobo 44
    Help: 28
    Rate: 196
    In this system, the connection will never be caught by the relay, because in the position of the lights not turned on, the second wire of the coil will not be given a minus so that the coil will catch, so after giving the plus when the position lights are turned on, the relay will not disconnect because it was never turned on.
  • #8 16184725
    jaga134
    Help: 88
    Rate: 192
    Really not given a minus? Well, probably when the light bulb is burned out.
  • #9 16184763
    bobo 44
    Help: 28
    Rate: 196
    Does a colleague have such a layout in mind?
    • Astra H Daytime Running Lights Installation: Connecting to Ignition Switch, Ground & Parking Bulb rysunek światel.jpg (77.01 KB) You must be logged in to download this attachment.
  • #10 16184955
    jaga134
    Help: 88
    Rate: 192
    Yes. Although, if the position lights are made on LEDs, such a circuit may not work.
  • #11 16184969
    bobo 44
    Help: 28
    Rate: 196
    I have some concerns about this, but I will check first, please explain why it works dry and on the engine attached, what's the difference.
  • #12 16185101
    jaga134
    Help: 88
    Rate: 192
    Maybe the error lies in the fact that with the alternator not working the voltage on the battery is lower than when the alternator is charging, i.e. the engine is running. The voltage detection system installed in the daytime running lights controller starts to "go dumb" and hence such a phenomenon. I used the BartSoft driver for my Scenic. The lights turn on when the voltage rises above 13.5V.
    Added after 6 [minutes]:
    To find out that this flashing while the engine is running has nothing to do with powering the parking / position lights / I suggest that the control cable, probably white, connect to the dipped beam bulb. Observe if something changes then.
  • #13 16185160
    bobo 44
    Help: 28
    Rate: 196
    I guess it is not related to the increase in voltage on the battery, because with the connection given above, the voltage through the relay contact will also be greater, once and twice, I have already fixed the cable straight from the battery, where there is more voltage, the system works correctly, so rather the daytime lights controller does not do it, if someone has a wiring diagram for headlights, I would be grateful.
  • #14 16185234
    jaga134
    Help: 88
    Rate: 192
    Write to me on priv. We will not deal with the forum with a topic that not everyone is interested in.
  • #15 16185257
    lopr_pol
    Level 32  
    Help: 164
    Rate: 491
    Uec tests the bulbs on the lights off and probably it stimulates the daytime controller to turn off. Connect through the relay, it will probably work, with a plus, for example, on the key to the relay's executive contact and to the controller of the daytime, relay coil with positional.
The discussion revolves around the installation of daytime running lights (DRLs) in an Astra H, specifically addressing issues with wiring connections to the ignition switch, ground, and parking bulb. The user reports that the DRLs behave incorrectly when the engine is running, failing to turn off as intended. Several participants suggest using a relay to control the DRLs via the parking lights, but the user encounters voltage drop issues that prevent the relay from functioning properly. Solutions involve connecting the relay coil to the ignition switch and the parking light power supply, but concerns arise regarding the voltage levels when the engine is off versus running. The conversation highlights the importance of proper wiring and voltage management in DRL installations.
