Oepl Astra G: Query on Electrical Installations for Hook Assembly Using Rear Lamps
lukpio3 23163 10
Can I take the trailer position and brake-light signals from only one rear lamp in an Opel Astra G, or should I run separate wires from the left and right rear lamps?
Take the brake-light signal from one lamp, but wire the left and right position lights separately; do not join the parking-light outputs together because each one has its own contact in the trailer socket [#16678253] [#16678264] [#16678265]
  • #1 16678245
    lukpio3
    Rate: 169
    Welcome,
    Yesterday I mounted the hook in Astra G, I've put together everything and today I am planning to install myself. Unfortunately, I do not have the original beam so I will install the installation from the rear lamps. And therefore I have a question for you because I met with different opinions. Can lights such as: position or stop pull only from one lamp? Is it possible to pull a separate wire from the right-hand lamp, separate from the left-hand lamp and connect both cables in the socket?
  • #2 16678253
    ftp.kowal
    Level 36  
    Help: 331
    Rate: 1843
    Stop with one lamp, position with both.
  • #3 16678264
    jakubwaba
    Help: 58
    Rate: 105
    Do not connect with each other, each position light has its contact in the trailer socket.
  • #4 16678265
    kkknc
    Help: 1915
    Rate: 6709
    You have separate left and right parking pins. You do not connect them together.
  • #5 16678280
    andrzej20001
    Help: 1578
    Rate: 6669
    Astra G = module. You have a PWM stop-stop. You can stop from the central alloy. But the module must be.
  • #6 16678284
    jakubwaba
    Help: 58
    Rate: 105
    In stop G, stop lights are on a normal two-filament bulb, so where your friend sees PWM modulation, I do not know ...
  • #7 16678286
    lukpio3
    Rate: 169
    Astra G and module ?? Nieee, astra H I have a module but G is a simple car :) . Even in the manual there is absolutely nothing mentioned about the module :)
    And I would like to ask you gentlemen, because my Astra is from 2008 so Polish, production in Gliwice, does not have the original hook beam, do you razicie protect the circuit with some fuse? Maybe I should increase the fuse for directions and lights of parking and stop? I do not want the installation to be too heavy.
  • #8 16678294
    ALIBABA I
    Help: 223
    Rate: 537
    Hello, you did not give the year of this car, because it is cable cross-sections, I suggested installing a trailer power module, for example Reno Kango 2008, plugged directly into the rear lamps, after 3 months a balloon on the traction of the trailer plug disappears after the inspection installations are cables thick as a pen tip
    sturdy fuses, no cables, connection of the socket, with a section for position lights. like something is going to be at least one lamp, /// You will be visible ///
  • #9 16678299
    lukpio3
    Rate: 169
    That's what I asked for in the post above :) . The year of the car is 2008. Are there any universal modules or dedicated to the car?
  • #10 16678306
    ALIBABA I
    Help: 223
    Rate: 537
    The more you will increase the risk of a greater load
    Added after 5 [minutes]:
    lukpio3 wrote:
    That's what I asked for in the post above. The year of the car is 2008. Are there any universal modules or dedicated to the car?
    As I wrote, there was no post yet, you can use a universal one, there is a description of how to connect it
    and yet because I do not know if there is a blown bulb control system, if it is, then the universal one will not come
  • #11 16678339
    lukpio3
    Rate: 169
    But this module plugs in before installing the car or behind? I mean, do I cut the car's installation between the fuse box and the lamps, the part going to the cab I plug into the module and the second side of the module I release 2 cables and one for the car lamp and the other for the trailer beam? Or maybe I have to solder in the car's installation, release a piece of cable and connect these cables to the module on the one hand and on the other hand those going to the trailer?
    Added after 31 [minutes]:
    I have just called a car electrician who assembles several hooks a week and said that in the case of opel I can sleep peacefully and safely assemble without a module. He has installed hundreds of hooks for the G-astra, and he has never returned him with a complaint. For Renault, Peugeot says that yes, he would be afraid to mount a hook without a module and even the majority of manufacturers do the module in standard for these cars because they have cables as thin as hair but Opel is calculated with the supply all the more he spoke (because he knows my trailer ) that I have LED lamps at my disposal so the load said that I have one which in the standard lamp is charged by one light bulb.
The discussion revolves around the installation of a hook assembly on an Opel Astra G, specifically addressing the electrical connections for the rear lamps. The main query concerns whether it is feasible to connect position and stop lights from a single lamp or if separate wires should be run from each lamp to the trailer socket. Responses indicate that stop lights can be connected from one lamp, while position lights should have separate connections. It is emphasized that the Astra G does not require a module for installation, unlike other models such as Renault or Peugeot. The user also inquires about the necessity of fuses for the circuit and the possibility of using universal modules for the installation. A professional electrician's input suggests that the Astra G can be safely installed without a module, based on extensive experience with similar installations.
