Upgrade Interior Lighting Astra G 2 98r with Switch Option, Compatible Lamps & Rewiring Tips
bodziszczu 6783 6
  • #1 16799437
    bodziszczu
    Hello everyone, as in the topic, the problem concerns the interior lighting lamp. The lamp lights only when I open the door and not too long. The question is whether such a lamp with a switch as in the photo below will fit. Upgrade Interior Lighting Astra G 2 98r with Switch Option, Compatible Lamps & Rewiring Tips
    Sometimes it would be useful to turn on the light, especially if you are picking something inside. Ew, is it going to rewrite it somehow, add a switch or something. Thanks all in advance for the answers ;)
    The wiring diagram is already downloaded and I'm reading right away.
  • #2 16800339
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    The interior light comes on by pulling the light switch towards you. :)
  • #3 16800522
  • #4 16801685
    bodziszczu
    Really? I didn't know that: '), I'll check it tomorrow morning!
  • #5 16801802
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4187
    bubus1769 wrote:
    As T5 gave and if you want to add a lamp with reading lights and you did not have them before, the installation probably does not include it and you would have to add extra weight.
    Please read my post :) I have not written anything about another lamp. They are interchangeable and work P @ P.
  • #6 16801895
  • #7 16832634
    bodziszczu
    Gentlemen, thanks again for your help, just pull the light switch towards you and it works :D
    I close the topic
The discussion revolves around upgrading the interior lighting of an Astra G 2 (1998 model) to include a switch option for better control. The original lamp only activates when the door is opened, and the user seeks advice on compatibility with a new lamp featuring a switch. Responses indicate that the interior light can be activated by pulling the switch, and that while interchangeable lamps exist, some may require additional wiring, such as a ground cable, especially if adding reading lights. The user confirms the solution works after testing the switch functionality.
