Optimizing Simar 15kW Eco-Pea Furnace Settings for 80sqm House with 7 Radiators and High Draft
arek.golawski1991 11613 5
  • Seeking settings to reduce Simar furnace fuel use and ash
    #1 16183208
    arek.golawski1991
    Hello, I have an oroblem with a simar 15kw furnace I burn a lot of eco-pea and it is very much ash burns 30kg a day I heat 80mkw high on 3m I have a floor in the bathroom and 7 radiator house old meter walls new windows with 3 windows house not insulated
    My settings
    Fuel supply 10s
    Interrupting interval65s
    Dmuchawa1
    In maintaining 10min
    Multiplicity 1
    Maybe you can help me have a big chimney draft and a further blower at a minimum
  • #2 16183344
    bearq
    Help: 414
    Rate: 1616
    Poor peas, how much ash you have left. The furnace can not be set via the Internet, you must see how the fuel burns, do not retreat the heat, etc. Although 30kg / day is also not a big result, especially in a non-insulated home.
  • #3 16183380
    arek.golawski1991
    Looks good burns do not fall out of the retort sinters too, there is only a small lumps are, a small mound is the temp. The stove is 15stop ba furnace zsdane 60stopni
  • Checking ash and sinter formation to assess furnace settings
    #4 16184299
    bearq
    Help: 414
    Rate: 1616
    Well, if you do not become sinters and only ash, or in the form of small aggregations, there is nothing more to combine here. If the settings were unsuitable, there would be peas in the ash pit, large sinters would form. You can pay attention to whether there is too much time between administrations, it shows a backfire and a large drop in temperature on the stove where later "heating up" the oven to set temperature takes a long time which translates into a long blower life and quick fuel burn. Unfortunately, here the main role is played by fuel and its calorific value.
  • #5 16186688
    arek.golawski1991
    I have a blend of eco-pea, I do not know what calorific value is 28 or so, I was told by the seller, the temperature drops by 3.5 degrees and slowly grows up maybe I will try another eco-pea, but I do not know if it is good and has only caloric value 26
  • #6 16901080
    marant36
    Rate: 23
    check if the flap in the blower fan closes automatically?
    in most of the blowers the pressure of the flap is regulated by two nuts.
    It has to open only when the fan is turned on.
    It seems that, as you write yourself, you have a strong chimney draft, and it is possible that this flap is always up and the stove works round the clock because it gets WILD AIR.
