What 27 'monitor with an IPS matrix to buy up to PLN 1000?
andi8877 2679 12
Which 27-inch IPS monitor should I buy for home use and occasional photo editing with a budget of about PLN 1000?
A good choice in this budget is the Dell P2714H, which is only slightly above PLN 1000 and is praised for good colors, a stable steel stand with pivot, a built-in power supply, DisplayPort, and a USB 2.0 hub [#16183703] Another strong option is the Samsung S27F350FHUX, which uses a good PLS panel treated as Samsung’s IPS alternative [#16185496] The iiyama ProLite XUB2790HS-B1 is also recommended as a solid alternative [#16185893] The AOC I2781FH has an AH-IPS panel, but one reply points out uneven backlight as its main drawback, while Samsung PLS was seen as looking very good [#16190423] If you buy online, it may be worth using the 14-day return window and checking the panel early; EIZO was mentioned as a reputable but more expensive option, with IPS models starting around PLN 1300 [#16195896][#16224523][#16226257]
  • #1 16183365
    andi8877
    Rate: 18
    I would like to buy a 27-inch monitor with an IPS matrix to be used mainly at home (internet, film, photos, Office suite, etc.). I also plan to edit photos from time to time. The budget is about PLN 1,000.
    My types are:
    AOC I2781FH
    Samsung S27F350FHU
    LG 27MP65HQ-P
    What do you recommend? Maybe you have an opinion on these? Please help.
  • #2 16183703
    oskar777
    Help: 76
    Rate: 243
    Hello, I recommend the Dell P2714H model a little over 1k but not much.
    Advantages:
    - it works
    - it reproduces the colors nicely in my opinion
    - stable steel base (in a plastic housing) + pivot
    - built-in power supply
    - menu with buttons, I have 3 monitors for 2 years and they all work ok.
    - displayport
    - usb hub but only usb2
    Oscar
    Oskar-info
    Gidzińskiego 24/1, Warszawa, 02-293 | Tel.: 501XXXXXX (Show) | Company Website: http://oskar-info.pl
  • #4 16185893
  • Questions about AOC panel origin and Samsung PLS durability
    #5 16189071
    andi8877
    Rate: 18
    Thanks for the suggestions. Pretty interesting. I will consider.
    This AOC I2781FH that I replaced has IPS matrices from what manufacturer? Samsung or LG?
    I stuck to this monitor because the manufacturer gives it a three-year warranty (competition only two), it has 2xHDMI and it looks interesting. Unfortunately, I don't know this company.
    Unfortunately, I was very disaffected with LG. In my family I have three LG 23 'IPS monitors and after a short time all of them have some crimson spots from the edges.
    Are such eggs also made in Samsung PLS? What does Samsung backlight look like in this price range? Or does the trail monitor go after time?
  • #6 16190423
    KrzysziuN
    Help: 6
    Rate: 78
    There is an AH-IPS matrix - it is ok, the only downside is the uneven backlight.
    I don't know exactly what the crimson edges are about :P but this is typical for IPS matrices if we are talking about bleeding here
    I saw Samsung at the exhibition so it's hard for me to say but the matrix was great :)
  • #7 16191843
    andi8877
    Rate: 18
    I have described the problem in detail here Link
    Since AOC may have a problem with uneven backlighting, maybe it is worth choosing this Samsung despite the shorter warranty. Should the backlight be okay and will it start bleeding after a while?
  • #8 16193223
    KrzysziuN
    Help: 6
    Rate: 78
    I haven't heard of such a problem in PLS, but it's best to see for yourself
  • #9 16194396
    andi8877
    Rate: 18
    I am not able to check this in the store because the mentioned problem occurs after some time of use.
  • #10 16195896
    KrzysziuN
    Help: 6
    Rate: 78
    This may be another internet purchase option then as something like 14 days return. There is a nice program from EIZO that you can check the matrices at the very beginning.
  • #11 16197381
    andi8877
    Rate: 18
    These problems occur on LG monitors after about 1.5 years, with three monitors in the family.
  • Considering Eizo EV2450 despite smaller size and higher cost
    #12 16224523
    andi8877
    Rate: 18
    What do you think about the Eizo or Nec brands? You can read a lot about them on the Internet. They are supposed to make excellent monitors for graphic designers. Unfortunately, their prices are cosmic. But they also have low-end monitors, the so-called office monitors. For example, the Eizo company offers the "EIZO FLEXSCAN 23.8" (EV2450-BK) "monitor. Yes, I know ... the monitor is not 27 inch and costs over PLN 1000, but maybe it is worth giving up a larger monitor and adding something to have something reputable with 5-year warranty, and maybe a solid one?
  • #13 16226257
    KrzysziuN
    Help: 6
    Rate: 78
    EIZO has very professional monitors only that the IPS price starts at 1300.
The discussion revolves around selecting a 27-inch monitor with an IPS matrix within a budget of PLN 1,000, primarily for home use including internet browsing, film watching, photo editing, and office tasks. The user considers models such as AOC I2781FH, Samsung S27F350FHU, and LG 27MP65HQ-P. Recommendations include the Dell P2714H, noted for its color reproduction and stability, and the Samsung S27F350FHUX, which features good PLS technology. Concerns about uneven backlighting and color bleeding in IPS panels, particularly with LG monitors, are raised. The user also explores the possibility of investing in higher-end brands like EIZO and NEC for better quality, despite their higher price points.
