GTX 1060 Monitor: AOC i2481FXH vs Iiyama G-Master Black Hawk GE2488HS-B2 - 60Hz vs 75Hz & IPS vs TN
ElemeleZi 4926 6
  • #1 16590394
    ElemeleZi
    Level 4  
    I decided on the 60hz monitor because I didn't find anything profitable on the market for 144hz and I have to spend +/- 800 zlotys
    24 inches 1920x1080 is the standard for me, I don't want anything more. I don't know if the ips matrix in this case is okay because I know that this first monitor has a tn that is worse than ips but it is known not only that it affects the final effect. can 75 Hz be felt in relation to 60 Hz?
    I have an eye on these two monitors, which one is better in your opinion?
    https://www.euro.com.pl/monitory-led-i-lcd/aoc-i2481fxh.bhtml?from=benchmark&p=619.00&cr=0
    https://www.morele.net/monitor-iiyama-g-master-black-hawk-ge2488hs-b2-649008/
    Or maybe look for something 144hz at this price or rather weak?
  • #2 16590465
  • #3 16590521
    ElemeleZi
    Level 4  
    And what monitor would you recommend me if my budget would be 1200 PLN?
  • #4 16590552
  • #5 16590591
    ElemeleZi
    Level 4  
    I just want to refresh the screen 120, 144 hz, but I do not want the quality of these hz to be worse than those after 700, 800 zlotys because 144hz and not 60hz
  • #7 16594401
    partizip2
    As for the iiyama you gave, I would not take exactly this, but a refreshed version. It came out about a month ago and there is Black Hawk on thinner frames, with 24.5 inch matrix for 699 PLN (I send the link in case: https://iiyama-sklep.pl/410-monitory-dla-graczy-iiyama-g-master -monitor-iiyama-g-master-g2530hsu-b1-25-black-hawk-24-1ms-fullhd-free-sync-guarantee-the zero-pixel-4948570115433.html). Other parameters are the same or similar. It pays more. And when it comes to design, it also looks better in my opinion. I had the opportunity to watch and use a friend, give advice. Under GTX 1060 there should be approx.
The discussion revolves around the choice between two monitors, the AOC i2481FXH and the Iiyama G-Master Black Hawk GE2488HS-B2, focusing on their specifications of 60Hz vs 75Hz refresh rates and IPS vs TN panel technologies. The user is considering a budget of approximately 800 PLN and is uncertain about the impact of refresh rates on gaming performance, particularly with a GTX 1060 graphics card. Responses suggest that while 75Hz can provide a smoother experience in dynamic games compared to 60Hz, the quality of the panel (IPS vs TN) also significantly affects visual performance. Recommendations include exploring other models, such as the LG 24GM77-B for 144Hz refresh rates, and a newer version of the Iiyama monitor with improved design and specifications. The conversation highlights the importance of balancing refresh rates, panel quality, and budget constraints when selecting a monitor.
