The micro USB cable has stopped charging
Mateusz7LT 4833 5
  • Micro USB cable failure confirmed across multiple devices
    #1 16184596
    Mateusz7LT
    I have a problem with the micro USB cable, for some time since the purchase everything worked and sent data loaded under the computer and on various USB chargers. Later suddenly it stopped being visible through my Phone (Pentagram X5 Pro) after turning off it shows that it is charging, but not charging. after switching on the device no reaction and after repeated connection. I will add that I also used it to pad Xbox One to connect to the PC and also stopped detecting the computer ... Other devices under it work just like my Phone and Pad under other cables, Just not on this.
    Can he fix it somehow?
  • #2 16184602
    Harcguitar
    It is difficult with cables because it is not known where. It is 99% damaged with the tip on one side or the other. The easiest way is to take a scalpel. Open both ends. Check with a meter that veins it breaks (probably GND. But does it pay off? The cable will not look like it and the new one costs a penny.
  • #3 16186215
    Freddy
    Help: 1394
    Rate: 2821
    Harcguitar wrote:
    The easiest way is to take a scalpel. Open both ends ...
    The easiest way is to buy a new one for PLN 5 :) .
  • #4 16186325
    Harcguitar
    The request was to explain how to fix it and whether it could be done at all. So you can get tired but it's worth asking yourself is it worth it?
  • #5 16191291
    Mateusz7LT
    I was hoping that I could do it less invasively, because, as I wrote, the USB cable seems to be efficient both in data transfer and charging only. Not on my devices and this is not a defect of the devices because other cables work and for this specific I gave about 20 zlotys in euros home appliances ...
  • #6 16191865
    Freddy
    Help: 1394
    Rate: 2821
    Mateusz7LT wrote:
    for this particular I gave about PLN 20 in euros for home appliances ...
    :) These are the prices. Buy a company cable, you will pay more, but it will last longer. You can buy Chinese for 2-5 zlotys, but they will be as they are.
