Sony Xperia M4 Aqua Charging Issue: Micro USB Plugs for Cable Mounting - Phone Not Recognizing
maro198805 4194 14
Why doesn’t a Sony Xperia M4 Aqua detect charging from a homemade micro-USB plug, and what must be connected in the plug?
The phone needs the USB data lines to be handled as well as power: connect +5 V to pin 1 and ground to pin 5, leave pin 4 unconnected, and bridge pins 2 and 3 with about a 200–220 ohm resistor so the charger is detected [#16485017][#16486667][#16487458] Bridging pins 4 and 5 is for OTG adapters, not for charging [#16486667] If the cable then charges but the phone behaves erratically, the charger itself may be poor or unstable; one reply also noted that a non-original charger can cause strange output voltages [#16488579][#16489147]
  • #1 16484684
    maro198805
    Rate: 23
    Hello, I recently bought a set of 10 micro USB plugs for cable mounting. I decided to use one to make an extra charger for my Sony Xperia M4 Aqua so I could have a spare. I soldered the wire as shown in the picture, i.e. pin 1 + 5V, pin 5 -5V.
    However, the phone does not see the charger and does not start charging. What could be the reason? Do you need to short something else in the plug? Sony Xperia M4 Aqua Charging Issue: Micro USB Plugs for Cable Mounting - Phone Not Recognizing
  • #2 16484702
    sosarek
    Help: 9320
    Rate: 15541
    Enter "micro USB sense" in Google, it will all be explained ;)
    Z
    Pka, Poznań, 60-850
  • #3 16484712
    maro198805
    Rate: 23
    I understand that we combine mass with sense, i.e. 4 out of 5?
  • #4 16484714
    sosarek
    Help: 9320
    Rate: 15541
    After all, you have everything explained and presented in the graphics, so why are you asking?
    Z
    Pka, Poznań, 60-850
  • #5 16484752
    maro198805
    Rate: 23
    I connected to pin 1 + 5V on 4 and 5 -5V, the phone does not respond, but on the phone of the father, Samsung Galaxy S3 sees a connected USB device but also does not charge. I will add that the charger is of course functional.
  • #6 16485017
    nutergsm
    Help: 1034
    Rate: 1666
    http://pinoutguide.com/ChargersAdapters/micro_usb_charger_pinout.shtml
    I personally made a charging and data cable.
    Here you have pinut usb http://pinouts.ru/Slots/USB_pinout.shtml and here micro usb http://pinoutguide.com/ChargersAdapters/micro_usb_charger_pinout.shtml
    You connect both plugs with a four-core cable, pin No. 4 in the micro usb plug is not connected.
    With the cable made in this way, I charge phones, tablets, navigations, webcams or a bluetooth speaker. It has never happened to me not to charge something or connect to a computer.
  • #7 16486588
    maro198805
    Rate: 23
    The original chargers also have two wires + red and - black, so I do not understand why the phone does not see the plug made like this? I also made an additional connection of pins 4 and 5 so that the phone detects the charger.
  • #8 16486667
    nutergsm
    Help: 1034
    Rate: 1666
    This connection is used for USB OTG adapters.
    In the micro usb plug you bridge pins 2 and 3 through a 200 ohm resistor and then it should correctly detect the charger.
  • #9 16486766
    piwko
    Help: 87
    Rate: 214
    There was already https://www.elektroda.pl/rtvforum/topic996132.html
  • #10 16486930
    maro198805
    Rate: 23
    Tomorrow I will try the option with this 200 Ohm resistor. It turns out that the phones on pins 2 and 3 have charging control and without them there is no charging. Unless I'm wrong?
  • #11 16487030
    piwko
    Help: 87
    Rate: 214
    Samsung with such a resistor does not charge, I also checked Sony and some Sagem, both work.
  • #12 16487458
    maro198805
    Rate: 23
    unfortunately, after connecting the 220 ohm resistor and trying to charge, the phone crashes, sees the charger and charges, but turns on the functions itself and goes between the screens. There is no diagram of how the original charger plug is connected, I mean what pin to connect to? I found such a diagram but then it was written to remove the resistor, unfortunately I do not know whether to put a jumper in its place or leave it without anything?
    One charger, when the voltage on the plug is 3.7 V, the other 10.42 (measurements without load), strange because each one says 5V?
  • #13 16488579
    Adrian4477
    Help: 179
    Rate: 184
    Do you add the USB cable to the original charger or do you have a charger from some strange device? Non-original chargers can muck so badly at the output that such things happen as you write.
  • #14 16488772
    mobista
    Help: 257
    Rate: 365
    Are you looking for around in my opinion - have you connected the ground to the housing?
  • #15 16489147
    maro198805
    Rate: 23
    The charger was from Nokia 500 and I bought the plugs on the Allegro.
The discussion revolves around a charging issue with the Sony Xperia M4 Aqua after the user attempted to create a custom charger using micro USB plugs. The user soldered connections to pins 1 (+5V) and 5 (-5V) but the phone did not recognize the charger. Various suggestions were made, including the need to connect pin 4 and the importance of bridging pins 2 and 3 with a resistor for proper charging detection. The user also experimented with different configurations, including adding a 200-ohm resistor, but faced issues with the phone malfunctioning. Concerns were raised about the quality of the charger used and the necessity of proper grounding. The conversation highlights the technical intricacies of micro USB charging connections and the potential pitfalls of DIY charger modifications.
