Galaxy S6 Charging Issue: Unresponsive to Different Cables, Possible Shorter Pin
Reve47 4083 5
  • #1 17295152
    Reve47
    Hello, I have a problem loading my Galaxy s6.
    Just yesterday everything worked smoothly, and suddenly after connecting the charger the phone does not respond. I tried on different cables, original and unoriginal. The nest is cleaned of dust. After looking into them, I have the impression that one of the "teeth" was shorter than the others. The phone has now fallen due to a low battery. Is there any method of repairing this besides the service / warranty?
  • #2 17295155
    D_Mrozu
    Help: 31
    Rate: 94
    Maybe this is not a repair method but ... You can charge the phone wirelessly - just buy a pad.
    Regards.
  • #3 17295156
    Reve47
    I think it will be one of the final solutions if no other is found. I will add that once there was a similar problem, with the difference that it was enough to slightly lift the cable. However, after some time the problem ceased to this day.
  • #4 17295190
    rabus40
    Rate: 14
    Hello !
    I suggest replacing the charging socket. It is not necessary to remove the lcd for replacement.
  • #5 17295192
    Reve47
    rabus40 wrote:
    Hello !
    What can be the approximate price of such an exchange?
  • #6 17295517
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    Ask at your local site, we don't rate repairs on the forum.
