GOLF 4 1.4 16V Engine Replacement: Estimated Costs and Experiences
rader1990 27477 12
How much does it cost to replace the engine in a Golf 4 1.4 16V?
A same-engine swap can start at about 3,000 PLN, but a more realistic budget is around 4,000–5,000 PLN once you add the used engine, replacement work, fluids, and timing parts. One reply says you may fit into 3,000 PLN if you only swap for the same unit and choose minimal extras, but the engine price is the biggest factor [#16186698] Another estimates 400 PLN for the job itself [#16187619], while a more detailed experience says a friend spent almost 4,000 PLN on an acceptable engine plus replacement, fluids, timing, and related work, ending at 5,000 PLN total [#16187632] It is also recommended to buy the same engine code, and to check or replace the clutch and timing components, because the condition of used engines varies a lot [#16186698][#16187675]
  • #1 16186616
    rader1990
    Hello, I have to replace the engine in the Golf 4 1.4 16v but I do not know how much I should put down the money. He was smothered by the frozen rejection. And I have no idea how much it costs.
  • #2 16186698
    bart1500
    Help: 12
    Rate: 66
    As you exchange for the same, you can fit into 3. It depends on what you will want to replace. Maybe it's worth seeing the clutch? Colleague exchanging the engine, replaced only the timing belt without pump, rollers. Whoever prefers. Well, but the biggest role is played by the price of the engine. How much will you want to give.
    I just do not know if it makes sense to change the engine at all. Is not it better to sell a car for parts and buy another one.
  • #3 16186751
    rader1990
    I honestly thought to sell it, but six months. ago I exchanged shields and pads, new summer tires, etc. I put in 3,500 zlotys, now it will not break again. A new car, new costs, and here I will know what I have.
  • #4 16186764
    bart1500
    Help: 12
    Rate: 66
    Yeah. If you buy an engine of unknown origin, you will actually know what you have ...
  • #5 16187097
    Eidems
    Help: 83
    Rate: 253
    And if he buys another car, will he see what he has? Charges also cost me, I see that a lot of people do not oversee the car on themselves, where OC, tax for the treasury, boards etc.?
  • #6 16187127
    bart1500
    Help: 12
    Rate: 66
    It is known that the best way is to buy a used engine, its renovation. Only economical? This engine does not even have power ...
  • #7 16187372
    Eidems
    Help: 83
    Rate: 253
    Well, because the power is only 1.8t or 3.2, people do you with this power. This new focus 1.6 85km also has no power?
  • #8 16187619
    zfv
    rader1990 wrote:
    HOW IT WILL REFUND TO CHANGE GOLF 4 1,4 16V ENGINE
    rader1990 09 Jan 2017 19:38
    400
  • #9 16187632
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    You did not give the symbol of the engine, but make a real 5,000, because these engines are falling like flies (German smelts from the Wagene) defects with freezing refusals. And because of this, the huge demand for these engines for replacing is not so sure that you can easily find something.
    A friend from 5 years ago spent almost 4 thousand on the acceptable condition of the engine + replacement, + fluids, timing, etc. 5,000 came out.
  • #10 16187640
    bart1500
    Help: 12
    Rate: 66
    Have you ever driven by this.1.4? When I had Astra 1.4, VW took no trouble at traffic lights. Such engines as 1.4 and 1.6 from VW should not be created at all.
  • #11 16187675
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    3.6 blocks, with new timing and oil, I bought in Bytom there are engines from English, visually and now it turned out to be 1st class.
    These engines, how efficient they drive nicely as for their power.
    Only buy with the same code because everyone is different from each other.
  • #12 16187755
    bart1500
    Help: 12
    Rate: 66
    Well, is not it better to buy a slightly taunted Englishman? Take the engine, maybe something else is useful. The rest for parts and go out for 0? Or even a little forward
  • #13 16187883
    Help: 1405
    Rate: 6430
    You do not buy an anglika at this price, and the timing and engine drive comes to this and it costs a lot.
The discussion revolves around the costs and considerations involved in replacing the engine of a Volkswagen Golf 4 1.4 16V, which has suffered from a frozen rejection. Participants share their experiences and insights on engine replacement, suggesting that the cost can range significantly, with estimates around 4,000 to 5,000 zlotys for a used engine and associated repairs. Some recommend considering the purchase of a used engine from a reliable source, while others question the value of replacing the engine versus selling the car for parts. The importance of ensuring compatibility with the engine code is emphasized, as well as the potential for hidden costs in acquiring a new vehicle.
