Samsung DW-FN320T - dishwasher and damaged AQUA-STOP question
PAWEŁ74 10197 17
How does the aqua-stop valve work in this Samsung dishwasher, and is there a separate solenoid valve inside the dishwasher itself for normal water intake?
In this Samsung model, the aqua-stop hose assembly is the only electrovalve that lets water into the dishwasher, so there is no separate inlet solenoid valve inside the machine [#16192661][#16190674] If the dishwasher shows a 4E/E4 fill error and no water reaches the tub, check whether the aqua-stop valve actually passes water, whether the filter or water jacket is clogged, and whether the valve coil has continuity [#16192461][#16190839][#16190674] A practical test is to disconnect the hose from the water jacket and verify whether water flows and whether the valve is blocked; in the thread, blowing through the hose felt like a closed ball valve, confirming the valve was shut [#16192560][#16192661] The author solved the fault by replacing the aqua-stop valve/repair kit, which fitted the dishwasher without problems and restored normal operation [#16192461][#16192661]
  • #1 16189312
    PAWEŁ74
    Help: 78
    Rate: 119
    I have a question, namely whether the aqua-stop valve is also a valve that cuts off the water supply when the appropriate water level is reached or only cuts off the water at the time of a potential leak?
    Summing up, is there such a typical shut-off solenoid valve in the dishwasher itself or is the one made of aqua-stop the only one?
    Dishwasher model as in the topic.
  • #2 16189544
    Zbych034
    Help: 549
    Rate: 1415
    Aqua Stop only works on leaks.
    I mistakenly assumed that it is a sensor.
  • #3 16189631
    PAWEŁ74
    Help: 78
    Rate: 119
    So when I cut it, the dishwasher will work normally?
    I am asking because when I traced the water path, somehow I did not manage to find a typical solenoid valve ...
  • #4 16189859
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3382
    PAWEŁ74 wrote:
    is the aqua-stop valve also the valve that cuts off the water supply when the appropriate water level is reached or only cuts off the water at the time of a potential leak?
    Both.
  • #5 16189889
    PAWEŁ74
    Help: 78
    Rate: 119
    Gentlemen, at the moment I know as much as I knew before asking the question ...: /
    To nares - is there any cheaper way to repair my problem with that hose and the valve on it? I admit that I do not like buying a hose for 25% of the value of a new dishwasher ...: /
  • #6 16189913
    nares
    Help: 1515
    Rate: 3382
    What, the solenoid valve is on fire? If so, most third-party aqua stop hoses are adaptable.
  • #7 16189939
    PAWEŁ74
    Help: 78
    Rate: 119
    It displays an error 4E or E4, before that, a tap is shown informing about the probable turning off of the water supply, and after a few minutes just 4E ... The dishwasher normally starts tz. pours out potential water before the wash cycle starts and wants to draw water but no water is reaching. I note that 230V is present on the AQUA-STOP valve cube ...
    I wanted to undress it but it is so flooded that it probably cannot be possible without physically damaging it ...
    Do you have a workshop or something? Maybe you have a cheaper solution and I could, for example, drive up tomorrow afternoon?
  • #9 16190039
    PAWEŁ74
    Help: 78
    Rate: 119
    I understand that the diameters of these hoses are standard, yes? And I will have no problems with assembly?
  • #10 16190041
    nares
    Help: 1515
    Rate: 3382
    Sometimes you have to carve ;) but you can do it.
  • #11 16190047
    PAWEŁ74
    Help: 78
    Rate: 119
    I wonder if I should use a solenoid valve from the washing machine, everything would be hidden behind the furniture so my joyful creativity would not be visible ... :)
  • #12 16190057
    nares
    Help: 1515
    Rate: 3382
    PAWEŁ74 wrote:
    I wonder if I should use some solenoid valve from the washing machine
    It is possible, but it is already a sculpture ;)
  • #13 16190674
    zibi1971
    Help: 262
    Rate: 1118
    Let the author of the topic check everything first. Disconnect the hose from the water jacket and then check whether it actually lets out water. Perhaps the strainer is clogged or the water jacket is calcified. In dishwashers with an electric aqua-stop there is only one solenoid valve that allows water.
  • #14 16190839
    h jaworski
    Help: 466
    Rate: 717
    You also need to check whether the solenoid valve coil has a passage because it happens that they have a break, I had such cases in Samsung dishwashers.
    nares
    Help: 1515
    Rate: 3382
    h jaworski wrote:
    You also need to check whether the solenoid valve coil has a transition
    My colleague PAWEŁ74 has a profile of "automatic ventilation and air conditioning", so I think he started with that ;)
  • #16 16192461
    PAWEŁ74
    Help: 78
    Rate: 119
    ... I checked it as one of the first things ...
    Maybe I will provide more information ...
    Voltage appears on the wires of the AQUA-STOP coil when the dishwasher is to take water in. The dishwasher is 2.5 years old and has not been used too intensively, it looks like new. I tried to get to the valve on the hose but the manufacturer tried to make it as difficult as possible. The valve is completely filled with quite hard and thick plastic, which is discouraging and may cause mechanical damage to this valve ...
    Water certainly does not pass through the AQUA-STOP valve because you cannot even see any reaction after the hose (e.g. stress when pressure appears).
    I did not want to buy used parts, I purchased a repair kit from this auction:
    http://allegro.pl/show_item.php?item=6279340218
    The description includes:
    "Solenoid valve aquastop repair kit for Bosch Siemens Neff Gaggenau Constructa Bauknecht Vogica Whirlpool 263789 dishwasher"
    We will see how it comes, what the quality will be and whether it can be adapted to my dishwasher, and I can return it if necessary. And I will not fail to write about the effects and difficulties.
  • #17 16192560
    zibi1971
    Help: 262
    Rate: 1118
    It's a pity you don't listen to advice. There is little pressure behind the valve. Disconnect the hose from the water jacket and then everything will be clear.
  • #18 16192661
    PAWEŁ74
    Help: 78
    Rate: 119
    Behind the hose, already in the dishwasher, there is a transparent plastic module mounted on the water jacket. You can see the movement of water in it when the dishwasher is pumping out the water, I think that if the water passed through the AQUA-STOP valve, it would be easily visible. If something in this module was clogged and the AQUA-STOP valve, however, let water pass, it would certainly be visible in the hose.
    After unplugging the hose from the connector and trying to blow / draw air / water from the hose, you can clearly feel that the valve is closed. Feels the same as when you try to blow into a ball valve that is closed.
    Welcome back...
    Dishwasher repaired, works fine :D
    The solenoid valve bought at the above-mentioned auction fits the model of my dishwasher without any problems. Simple replacement without too much difficulty. The only difficulty I encountered was to put the housing on after assembly, it is hard to close it from the side of the hose, it does not quite fit the hose cover (conduit), maybe that's why they do not write that, it also fits Samsung. The valve "hums" a bit, but it does not bother you because the water consumed drowns out the hum, in my case even more negligible due to the fact that everything is completely built-up.
    In the model of the dishwasher from the subject, there is only one electro-valve, it cannot be omitted even for the time of getting a new AQUA-STOP valve, thus I answer my own question. Unless someone is standing and turning the valve from the connector 8-) which I do not recommend :not:
    The valve came with the necessary additional components, we don't need any additional parts. Personally, instead of crimping the ends of the cables with the provided sleeves, I soldered them and secured each one separately with a heat-shrinkable sleeve from my own resources, then put on the provided T-shirt and also welded it.
    I was planning a photo session of replacing this valve, but when I got into the vortex of work, I completely forgot about archiving my struggles :| . Especially since I wanted to finish before my lady comes home from work ... and when she started washing up, I asked why she was washing by hand if we had a dishwasher :lol: ?
    Thank you for all the help ...
✨ The discussion revolves around the Samsung DW-FN320T dishwasher and the functionality of its AQUA-STOP valve. Users clarify that the AQUA-STOP valve primarily functions to prevent leaks rather than controlling water supply based on water levels. The conversation includes troubleshooting steps for a malfunctioning dishwasher, specifically addressing error codes (4E or E4) and the potential blockage in the water path. Participants suggest checking the solenoid valve and the water jacket for clogs, and some share experiences with replacing the solenoid valve using a repair kit. The discussion concludes with a successful repair of the dishwasher after replacing the solenoid valve.
