Whirlpool ADP8797 Dishwasher: Resolving Alternating Error Codes E4 F4 - Drainage & Water Intake
dmu 11376 3
  • #1 16252358
    dmu
    After switching on the dishwasher it waits about 1 minute. and error E4 F4 appears alternately. I checked if there is no water at the bottom, if it drains water and it is OK. I have the impression that the water is not consumed but the relay has resistance so it is rather OK. Now it remains to check whether voltage is supplied to start the valve. But maybe you have any other ideas? Maybe it works differently and something is still being checked by the dishwasher before it starts taking water.
  • #2 16255796
    mirofalcon
    Help: 72
    Rate: 360
    Na pewno dobrze odczytałeś kod błędu bo w serwisówce nie mogę się dopatrzeć tego błędu.
    F1E1 - Pilot relay stuck on
    F1E2 - Parameter read failure
    F2E1 - Stuck key in User Interface
    F3E1 + F3E2 - Thermistor Open or Unplugged or...
    F3E3 + F3E4 - OWI Calibration Failure or OWI ...
    F4E1+F4E2 - VSM communication
    F4E3 - Wash motor not functioning
    F5E1 - Door switch stuck open
    F5E2 - Door switch stuck closed
    F6E1 + F6E3 - No water or low water/suds fail...
    F6E2 - Filling valve not functioning
    F6E3 - Low water/suds failure
    F6E4 - Overfilling
    F6E5 - Filling valve failure
    F6E7 - Flowmeter failure
    F6E8 - Regeneration valve not functioning
    F6E9 Water Tank Valve Not Functioning
    F6EA(10)/F6EB (11) - Leia Water tank valve st...
    F6EC (12) No water from water indicator
    F7E1 + F7E2 - Heater stuck on
    F8E2 + F8E3 - Drain motor stuck on
    F8E2 - Drain Motor Not Functioning
    F9E2 - Diverter motor stuck on
    F9E3 - Diverter disk failure
    FA(10)E3 - Drying fan not functioning
    FAE1(F10E1) - Dispenser not functioning
    FAE2 (F10E2) - Active Vent not functioning
  • OWI sensor pulses observed during water intake
    #3 16258099
    dmu
    I read it correctly. I suspect that the reason is the process of collecting water but I do not know what is going on and what the dishwasher's operating scheme looks like. I checked the OWI sensor, i.e. I took it out and after starting the dishwasher with the camera of the cell I observed light pulses. On the wires I see that the water enters the salt reservoir and I do not know what to do next.
  • #4 16277745
    dmu
    I called a crew, checked the dishwasher and pointed to the pump. The cost is about PLN 400. They made us think and canceled for arrival and diagnosis PLN 70. I disconnected the dishwasher from the network, checked the pump that I think works, connected to the network again and the dishwasher works without problems (the programmer has reset). In this way I paid amateurs for arrival and incompetence.
