Peugeot 307 HDI 2.0 136kM2004 - Error P2565 turbo topping high
Adam-1989 24369 5
  • #1 16189328
    Adam-1989
    Hello, I have a problem when driving at low speed, the car tugs most in 1, 2, 3 gear. The Antipollution Fault message lights up and the orange engine on the dashboard sometimes goes out for a while. The last time I drove 500km at some point in the 5th gear at 120 km / h the car lost power by pushing the gas car as if it caught the left air did not want to go faster I reduced it to 4 on then I had to go to the parking lot myself, turned off the engine, then started and everything was ok. After connecting to the computer error P 2565 and P 1598 pop up. Thank you in advance for your help.
  • #2 16189551
    madamsz1
    Help: 1053
    Rate: 1696
    It looks like there is a problem with the fuel delivery regulator on the pump. And P2565 for problems with the turbo compressor or its control.
  • #3 16192403
    Adam-1989
    . And with this control it's about this pear? and potentiometer mounted on 3 screws? after connecting to my computer I have such errors
    1. Thermostat solenoid valve short to plus
    2. Turbocharger feedback potentiometer short to positive pressure too high
    3. The air conditioning compressor is working.
    And that if it gets the left air can be FAP? filter clogged? fluid near the fuel tank I have because I checked.
  • #4 16193935
    madamsz1
    Help: 1053
    Rate: 1696
    I wouldn't worry about this valve (from the thermostat). As for the turbo, it can be everything from the control, valve, hoses, pear or even the variable geometry itself (or maybe only the computer does not read geometry from the sensor). It makes problems with the behavior of the car. I do not know what you mean left air, unless it is somewhere damaged any of the air hoses going from the turbo to the throttle, the effect can be similar to damage in the turbo - you need to look carefully at the entire intake, whether it is not damaged, or something is not heavily "sweaty" with oil, is the intercooler cooler tight.
    Mariusz
  • #5 16195035
    marcin_70
    Help: 38
    Rate: 269
    planets and observe the position of the turbo copy sensor if the set coincides with the actual value ... it will come out handy ..
  • #6 16506940
    Adam-1989
    So far I haven't solved the problem /// I looked into the turbine, I'm looking for everything ok. Maybe someone knows what else can be? Thank you
