Best Terrestrial TV Antenna for Sokółka, Podlasie: Recommendations for Białystok Transmitter (40km)
karol2266 22986 9
  • #1 16521485
    karol2266
    Rate: 19
    I'm going to buy a terrestrial antenna, and I'm green in this topic. I'm in Sokółka, Podlasie, and I will download the signal from the transmitter in Białystok (about 40km)
    I read that it is not worth buying for a strong antenna because then other "things" will interfere with its operation. I am asking for the best links from allegro.
    Thank you in advance for all your help
  • #3 16521641
    niewolno2
    Level 40  
    Help: 628
    Rate: 1255
    Please note in what polarization the transmitters send in your location and then check what the right antenna will be.
  • #4 16521728
    karol2266
    Rate: 19
    How do I check the polarity in my area?
    I have already found H, frequency 198.5
    Added after 3 [hours] 25 [minutes]:
    I forgot to add that I would like to set on 3 tv. Somewhere on the forum, people were praised by telmor antennas. I found such a set on allegro
    http://allegro.pl/zestaw-antena-dvb-t-telmor-asr-p20-na-2-3tv-1568d-i5250906347.html
    To the above proposal, you need to buy a power supply, rack, dealer, or the price will come out more or less the same.
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 272
    I gave the antenna for your location and all MUXs, but keep looking separation of the TV should be sufficient by a passive splitter.
    Possibly at large distances (between the TV and the place where the antenna is installed): https://www.telmor.pl/Katalog-produktow/Wzmac...ckie/RTA-120-RTA-140-aktywne-rozgalezniki-RTV.
  • #6 16521835
    karol2266
    Rate: 19
    Thank you I will buy the antenna proposed by you. The distance between the antenna and the furthest TV on the cable will be about 20m. I do not know if I gave a good distance from the transmitter because in total it can be slightly over 50km
  • #8 16521914
    karol2266
    Rate: 19
    Well, everything is clear. I gave it at the beginning of 40km because from the Sokółka sign to the sign Białystok is 42km (a straight line less) but I do not live on the edge of Sokółka and the transmitter does not stand on the outskirts of Białystok. I found such a set on 3 TV:
    http://allegro.pl/zestaw-antenowy-dipol-28-5-12-21-69-hv-dvb-t-3tv-i6793306031.html
    One more question. The antenna will not be placed above the roof, and on the wall of the building, will it not be a problem?
    Added after 2 [hours] 11 [minutes]:
    can this antenna be mounted on the wall of the building and not above the roof?
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 272
    Generally the higher the better, the problem may or may not be (or measurements before installation, or your own experiments).
    This set which in the link you showed I would assemble without the use of an amplifier, experiments with the amplifier only when despite all efforts the signal will turn out to be too weak.
  • #10 16522365
    karol2266
    Rate: 19
    Thanks I will
✨ The discussion revolves around selecting the best terrestrial TV antenna for receiving signals from the Białystok transmitter, located approximately 40 km from Sokółka, Podlasie. Users recommend antennas suitable for the local conditions, emphasizing the importance of polarization and the potential interference from strong antennas. Suggested models include the Dipol A2810 and Telmor ASR-P20, with considerations for additional components like power supplies and splitters for multiple TVs. Users also discuss the feasibility of wall-mounted installations versus elevated placements, noting that higher installations generally yield better reception.
