Mio Spirit 7500 LM: Automapa v6.25.1 1808 Crashes - _wceAm.exe Error & Solutions?
1808 12792 11
Why does Automapa 6.25.1 crash with the message "_wceAm.exe encountered a serious error" on a Mio Spirit 7500 LM, and how can I fix it?
The crash is most likely caused by Automapa 6.25/6.25.1 being unstable, and the suggested fix is to return to version 6.24 while using the 1808 map [#17501022] One working method is to install the full 6.24 program with map 1806 on a clean device, then start the 6.25.1 + 1808 installation in advanced mode and deselect the option that installs program 6.25.1, leaving only the map update [#17505519] That leaves you with program 6.24 and map 1808, which was reported to work [#17505519] Another reply adds that if you do use 6.25/6.25.1, a clean install with maximum memory limits set in the program settings can sometimes help [#17847106]
  • #1 17500872
    1808
    I have a Mio spirit 7500 LM navigation with Automapa on an SD card.
    Automapa version 6.25.1 1808. When navigating while driving, it pops up
    window with the message "Application _wceAm.exe encountered a serious error
    and must shut down. "and the program crashes.
    I sent a query to help AM, but I did not receive an answer.
    Maybe someone has such a problem here on the Forum? What is a cause of it?
    It seems to me that it was not in version 6.24. The window pops up irregularly.
    Sometimes after a few kilometers and sometimes several hundred.
  • #2 17501022
    jajacekpl
    Help: 65
    Rate: 268
    6.25 is unfinished. Return to 6.24 and add the 1808 map - it works very well
  • #3 17501131
    1808
    Thank you for the fast reponse. I have been navigating recently. Only what
    I can update it according to AM instructions. I do not know how to do it
    what the Lord suggests. I am afraid of "messing up" so as not to lose the license completely (AM
    it supervises the product very much and does not allow much)
    My IT education does not go beyond the eighties of the last century.
    Regards and I count on your understanding.
  • #4 17505425
    1808
    welcome back
    I repeat the question how to combine the older version of the AM program with the latest PL map?
    1 can I upload an older version of the SD card with the new AM (I have computer installations
    terra)?
    2 what to do to make a new PL map appear in the older version?
    3 if I do these activities, I will not lose my license?
    ta_tar
    Help: 700
    Rate: 2053
    If you have a license, install the entire program 6.24 on the clean tab with map 1806 and go through the entire procedure. Then initiate the installation of program 6.25.1 with map 1808, but select the advanced installation, then deselect the "bird" so that program 6.25.1 is not installed and go ahead. You will then only be able to update the 1808 map in the selection field and leave this "bird" here. Go through the entire procedure and you have program 6.24 and map 1808.
  • #6 17505722
    1808
    Thank you very much. I have what I want and it works !!
    By the way: I create a navigation route at home. I save it with the Menu-Route command
    -Modyfikuj-Save. Loading Menu-Route-Modify-Load. The route appears all on the screen.
    I am starting a car, but detailed navigation does not start.
    What should I do next?
  • #7 17505740
    ta_tar
    Help: 700
    Rate: 2053
    Check how your GPS signal is set. Do you have set "Run on startup"
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    After loading the saved route when you do not start navigating, you can click on this symbol with a white arrow (red indicator):
    And when this window appears, click on the symbol that the red arrow points to.
  • #9 17505956
    1808
    Thanks I checked on a short route and it's OK.
  • #10 17847048
    SKuba64
    I have the same problem. Everything worked until version 6.24. 6.25 works for a few minutes. Then there are several options:
    1) White screen with a blue road and nothing more
    2) The correct voice messages, on the indicators the kilometers are lost, but the screen with the road "frozen". It helps you to press the menu and return. But for a few minutes.
    3) Error message and disabling the program ...
    I tried to install new maps on the old program. Can not do it - "map incorrectly registered - register the map" and the end of the song.
    Driving with the old map - OK. until I miss a longer section of the new route (eg Jędrzejów - Brzegi). First, AM suggests that I change the route, then bravely shows me how to skip the fields, and then shows a strange message pointing to her dismay my driving through the fields and - the end of the job.
  • #11 17847077
    ta_tar
    Help: 700
    Rate: 2053
    6.25.1 is a program and which maps do you use? There is already a map of 1902.
  • #12 17847106
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    At the beginning, the only question is whether you use a "legal" program with a license or cracked, or "legal otherwise"? This "problem" with the 6.25 / 6.25.1 program is probably known for a long time (since its publication). Legal, with a legal license works perfectly, and "cracked", "otherwise legal" has such problems (program 6.24 "did not have"), security in the newer program has changed and the "patcher" does not work as it should.
    The second case, if you are using program 6.25 / 6.25.1, after the "clean" installation, during the first run set the maximum memory limits (in the program settings). Sometimes and in some types of devices it helps (apparently even with "legal otherwise" programs).
The discussion revolves around issues faced by users of the Mio Spirit 7500 LM navigation device running Automapa version 6.25.1 1808, which frequently crashes with the error message "_wceAm.exe encountered a serious error." Users suggest reverting to version 6.24 and updating the map to 1808 as a solution. Concerns about maintaining the software license during updates are raised, with advice provided on how to properly install the older version alongside the new map without losing the license. Additional troubleshooting tips include checking GPS settings and ensuring proper navigation route loading. Some users report similar problems with version 6.25, indicating that the issues may be linked to software changes and licensing status.
TL;DR: Automapa 6.25.1 on Mio Spirit 7500 LM shows 3 failure modes; "6.25 works for a few minutes." Fix by keeping program 6.24 and updating maps via Advanced install. This FAQ targets _wceAm.exe crashes and frozen screens. [Elektroda, SKuba64, post #17847048]
Why it matters: It helps Mio Spirit 7500 LM owners stop _wceAm.exe crashes without losing licenses or map updates.
Why does Automapa 6.25.1 crash on Mio Spirit 7500 LM?
Users report instability in program 6.25. A contributor wrote, “6.25 is unfinished. Return to 6.24 and add the 1808 map.” Rolling back improves reliability on the Mio Spirit 7500 LM. [Elektroda, jajacekpl, post #17501022]
How do I roll back to 6.24 and keep the 1808 map?
Use the Advanced installer to update maps only while keeping 6.24.
  1. Install 6.24 clean with map 1806. Activate and finish setup.
  2. Launch the 6.25.1 installer. Choose Advanced. Uncheck Program. Select map 1808.
  3. Complete installation. You now run 6.24 with map 1808. [Elektroda, ta_tar, post #17505519]
Will downgrading this way risk my Automapa license?
If you have a license and follow the process above, you keep it. The guidance starts with, “If you have a license…” Activate 6.24 first, then perform the map-only update. [Elektroda, ta_tar, post #17505519]
What does the “Application _wceAm.exe encountered a serious error” message mean?
It indicates the Automapa executable crashed and forced a shutdown. The fault appears during driving at irregular intervals, from a few to several hundred kilometers. [Elektroda, 1808, post #17500872]
What symptoms should I expect with the 6.25 issue?
Users describe three failure modes: white screen with a blue road, frozen display while voice guidance continues, and a fatal error with shutdown. Tapping Menu, then returning, may unfreeze it for minutes. [Elektroda, SKuba64, post #17847048]
How do I start navigation after loading a saved route?
After loading the route, tap the white arrow on the main screen. When the small window opens, tap the start arrow to begin navigation. [Elektroda, wojtek1234321, post #17505830]
Why doesn’t navigation start after loading a route?
Check GPS settings. Enable “Run on startup” so GPS initializes automatically. Without a GPS lock, the app shows the route but will not guide. [Elektroda, ta_tar, post #17505740]
How can I reduce freezes on 6.25/6.25.1 without downgrading?
Try a clean install and set maximum memory on first run. Open Settings and push memory sliders to maximum. Some devices stabilize after this change. [Elektroda, wojtek1234321, post #17847106]
Why do I get “map incorrectly registered — register the map” on old program + new maps?
This appears when the new map is not registered for your installation. Users who tried new maps on an old program saw this message and could not continue. [Elektroda, SKuba64, post #17847048]
What’s the latest map version mentioned, and should I use it?
The thread notes map version 1902 is available. If you use 6.25.1, ensure you select the desired map version during installation. [Elektroda, ta_tar, post #17847077]
Do cracked Automapa builds cause these crashes?
Yes. “Legal, with a legal license works perfectly,” while cracked builds exhibit freezes and errors. Use a licensed install to avoid added instability. [Elektroda, wojtek1234321, post #17847106]
Why does routing go “through fields” after a big detour on old maps?
Old maps miss newer roads. During long detours, AM may route across missing segments and then fail. Updating to newer maps reduces this risk. [Elektroda, SKuba64, post #17847048]
Is the crash timing predictable on 6.25.1?
No. Reports show the error appears irregularly. It can occur after a few kilometers or after several hundred. [Elektroda, 1808, post #17500872]
