Opel Meriva 1.6 Gasoline 2007: High City Fuel Consumption Issue - 12L vs 6L on Route
jordan1985 8835 9
Why does an Opel Meriva 1.6 gasoline 2007 burn about 12 L/100 km in the city but about 6 L/100 km on the road, even when the engine is warm?
In city driving, 12 L/100 km can be normal for a Meriva 1.6 gasoline, especially in winter, with frequent stops, short trips, and repeated starts from traffic lights, even if the engine is warm [#16193275][#16193283][#16194000][#16195805] The temporary fuel consumption at launch can exceed 20 L/100 km, so several hard starts in the city can raise the average a lot [#16193283][#16194000] If the consumption still seems too high, the thread points to checking the stored cylinder 3 fault, possible fuel leaks, cylinder compression, the second lambda probe, EGR, throttle body, catalyst, and injection pressure [#16199066][#16203746]
  • #1 16193261
    jordan1985
    Rate: 35
    Hello, I have a problem with Opel Meriva 1.6 gasoline 2007 mileage 180 thousand The car burns on a route of 6l economical driving and in a city of 12l and it is not on a cold engine but warm. Last time average fuel consumption was 9l. Coil new candles also lambda probe ok. On the route burning ok but the city so much. I drive without air conditioning.
  • #2 16193275
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Unfortunately, these are normal results in such weather conditions.
    Short episodes,
    underheated engine,
    frequent starting of a cold engine,
    interior heating switched on,
    high rolling resistance on snow,
    high speed blower on,
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16193283
    zyga c
    Help: 10
    Rate: 76
    Do you have "temporary fuel consumption" on the display? See how much you have when you start off in the first seconds? It certainly is or exceeds 20 l / 100. And how many such situations do you "take off" from under the lights. And this is average consumption.
  • #4 16193542
    jordan1985
    Rate: 35
    It is burning on a warm engine in mixed mode and yes I do not have a computer I do not know about temporary combustion
  • #5 16194000
    zyga c
    Help: 10
    Rate: 76
    If you had the opportunity to go with a friend who has a display with temporary fuel consumption - let them switch to this function and then you will find out what's going on. It doesn't matter if the engine is warm - the way of starting from the lights, and the consumption varies. My car / diesel / 1.4 td - medium on route 5 to 5.5, in city 8, but never the wheels squeak when starting - and comp. shows then 18. If I started with a bigger "break up" it would temporarily reach 25/100. Several such situations every day and an average of 15 l / 100 will come out.
  • #6 16194541
    jordan1985
    Rate: 35
    Only this average fuel consumption is like I was on the road all the time and then the city without a break. As if these were short episodes, I would agree. The heating is not only at half and the blowing is the same.
  • #7 16195805
    CameR
    Help: 1139
    Rate: 3272
    It made you curious:
    jordan1985 wrote:
    Heating is not only half full
    ... at an outside temperature of 23 degrees C. :-)
    I wrote the phrase "how much Meriva smokes you" on Google
    http://forum.opel24.com/topic/14346-ile-wam-pali-meriva/page-2
    ... and burning over 10l in the city is no wonder in this quite heavy car.
    ABC KOM
  • #8 16195824
    jordan1985
    Rate: 35
    It was measured at a temperature of -6. Economic driving up to 90 km. A combustion on average 9 liters. City for 12 or more
  • #9 16199066
    jordan1985
    Rate: 35
    During the week I have to see the pressure on the cylinders because the computer has an error on the 3rd cylinder I replaced candles. There may be some fuel leaks
  • #10 16203746
    jordan1985
    Rate: 35
    He was connected to a computer. The second probe hung up, slightly ignited Egr ignition and cleaning throttle and catalyst to check and measure injection pressure.
The discussion revolves around the high fuel consumption issue of a 2007 Opel Meriva 1.6 gasoline vehicle, which shows a discrepancy between highway consumption (6L/100km) and city consumption (12L/100km). The owner reports that the car has a mileage of 180,000 km and experiences this high city consumption even when the engine is warm. Various factors affecting fuel consumption are discussed, including driving habits, short trips, and external conditions such as temperature. Suggestions include checking temporary fuel consumption metrics, cylinder pressure, and potential fuel leaks. The owner has already replaced spark plugs and checked the lambda probe, but further diagnostics are recommended, including examining the EGR system and throttle body.
