Opel Vivaro 2011 2.0 CDTI: High Fuel Consumption, Smoke at 120km/h & Strange Exhaust Smell
WALDEK.PL 5604 4
  • #1 16772995
    WALDEK.PL
    The question is about the Opel Vivaro 2011 2.0 CDTI. The car started to smoke more on the road with no load (120 km / h), fuel consumption about 10L / 100km. A strange smell from the exhalation when firing. What is going on?
  • #2 16773036
    moto-kord
    Help: 137
    Rate: 505
    Hello, car with DPF.
  • #3 16773105
    WALDEK.PL
    How to check this DPF? Is it visible on the control?
    Is there any service mode? To check if all lights on the meter are working? Because, for example, there is no indicator from the open door, and when it is open, it does not light. It's so on the topic on the side.
  • #4 16773111
    moto-kord
    Help: 137
    Rate: 505
    The easiest way is to connect the car to a diagnostic device and check the parameters.
  • #5 16773131
    WALDEK.PL
    can you do it yourself?
    Added after 11 [hours] 2 [minutes]:
    I found something like this for diagnostics - SDPROG + iCar2 WIFi OBD2
    allegro.pl/sdprog-icar2-wifi-obd2-diagnostyka-silnik-opel-i6761800445.html
    Is there any other check option? Buy a cable and some software from the Internet? Any suggestions?
    thank you in advance,
