The blower does not work - Peugeot 406 2.0 hdi 2001 climatronic
rekinisko 15972 4
  • #1 16195373
    rekinisko
    Help: 42
    Rate: 142
    After the last frosts, verva froze me and I had trouble firing the lion king. The next day it turned out that the air blower was not working. I checked all the fuses in the cab and under the hood, they are good. In the place where 12V goes to the fan controller. Giving 12V a shortcut through the fuse, the supply starts. There goes a cream-colored cable with the inscription KH40 which disappears somewhere behind the storage compartment. I read that he was going on to the ignition station. I didn't get to the ignition switch that exactly, but it seems to me that there is no such cable on the cubes of the ignition. I wonder if there is anything else along the way and I hope it's not BSI because screwing it is probably not such a simple matter. I would like to add that successively strange things happen every year after the frost, the climate has stopped working, the wipers do not operate at a slower gear in the cold. Are these sometimes relays in BSI? Save my lion because it is 510,000 km and I want to finish up to a million and here the frost, the airflow does not work and nothing can be seen through the glass.
    The blower does not work - Peugeot 406 2.0 hdi 2001 climatronic The blower does not work - Peugeot 406 2.0 hdi 2001 climatronic The blower does not work - Peugeot 406 2.0 hdi 2001 climatronic
  • #2 16195784
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    It is likely that this cable goes to the other connector from the ignition switch cables.
  • #3 16196076
    rekinisko
    Help: 42
    Rate: 142
    I will check again. I will be grateful for any hints.
  • #4 17593930
    grzesiak83
    How did you solve the problem?
  • #5 17594243
    vogelek1
    Help: 36
    Rate: 114
    Two wires go directly to the blower module and in this module on the second pin you have direct mass or minus and on pin 1 you have plus directly from the 40A fuse which has power after the ignition i.e. 15.
    5 and 6 pin from this blower module goes to the AC panel
