Peugeot 307 2.0HDI 90HP RHY - 307 Klimatronic No Supply Air - BSI Relay Which
ak4777777 18777 7
  • #1 16400963
    ak4777777
    Rate: 11
    I have 307SW 2.0HDI 2003 with climatronic. The airflow stopped working, as I have an additional 206 2.0HDi with this type of climate control, I changed it:
    - blower
    - Klimatronica control panel
    - Interior temperature sensor with a motor
    - BSM under the bonnet (I have 206 full versions of BSM B5 here I will also be ahead of your questions. Additionally in 206 on BSM with 307 everything works except Lamp washers)
    I have only BSI left but I will not postpone it. There are relays in it, I have BSI. I just need to know which relay is responsible for the Blower and the Motor of the interior temp. (or how to bypass it, e.g. giving 12v on the key and not after starting the engine, this blower works at speeds)
    PP2000 still gives me an error Cabin temperature probe rotor blocked. And when the ignition is switched on, the dot on the Klimatronica panel flashes (from half * C) informing about a problem
    BSI Valeo J04
    (sample photo) Peugeot 307 2.0HDI 90HP RHY - 307 Klimatronic No Supply Air - BSI Relay Which
  • #2 16400981
    milejow
    Help: 1563
    Rate: 5149
    The blower power relay sits behind the BSI block, at least this is the case in Berlingo / Partner, I think in 307 too.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 16400986
    ak4777777
    Rate: 11
    Where behind the BSI block?
  • #4 16401000
    milejow
    Help: 1563
    Rate: 5149
    At the back, accessible after retracting BSI, the relay is powered by BSM. The standard fault is the burnt relay base.
    Działalność własna
  • #5 16401008
    ak4777777
    Rate: 11
    I don't have anything for BSI. It is completely empty, after unplugging BSI I have only cables and nothing more, no other fuses, relays nothing. the only thing is 3 Relays near BSM under the hood responsible for the electric heater
  • #6 16403644
    mario 77
    Help: 66
    Rate: 335
    And what about the blower control module? resistor / resistor?
  • #7 16403801
  • #8 16404122
    ak4777777
    Rate: 11
    I have already repaired, dismantled the entire installation from the French side and found a cable that broke
The discussion revolves around a Peugeot 307SW 2.0HDI (2003) experiencing a failure in the climatronic system, specifically the blower and interior temperature sensor. The user has replaced several components, including the blower, Klimatronica control panel, and BSM, but the issue persists. Responses indicate that the blower power relay is located behind the BSI block, which may be burnt out. The user notes that their BSI is empty, with only cables present, and mentions the presence of three relays near the BSM responsible for the electric heater. A suggestion is made to check the blower control module or resistor. Ultimately, the user resolved the issue by identifying a broken cable in the installation.
