Peugeot 207 1.4 VTI Air Conditioning Not Working: Thermostat Error, BSM Replacement, 2007 Model
patik1994 35355 13
Why won’t the air conditioning on a 2007 Peugeot 207 1.4 VTi with manual climate control work when there is an active thermostat error, even though refrigerant pressure is correct and the compressor runs when powered directly?
Yes — an active thermostat/temperature-sensor fault can prevent the air conditioning from starting, and several replies point to that circuit as the cause [#16548195][#18764009] One user solved the same problem by bypassing the thermostat, after which the A/C started working [#16548195] Another advised checking the temperature sensor on the aluminum wire with an ohmmeter and noted that replacing it restored A/C operation [#16540298] A further suggestion was to plug a 1 kOhm resistor into the sensor connector as a test, because without that sensor the climate system will not start [#18764009] There was also a separate report that an overloaded coil made the BSM cut power, so the control side and wiring should be checked if the compressor works when powered directly [#16552159]
  • Active thermostat fault may disable air conditioning
    #1 16539594
    patik1994
    Rate: 26
    Hello everyone interested in the topic.
    I have a Peugeot 207 1.4 VTI and I'm struggling with the air conditioning not working. The factor is, the right amount, no computer error from the sensor, the pressure reads correctly. BSM, after decoding the numbers, it was from Peugeot 307, but it is already replaced with what it should be. I'm curious about the fact. There is an active thermostat error, I heard that if this error is air conditioning will not work? I forgot to add, manual air conditioning, the car is from 2007. After applying voltage to the compressor, it turns on, the fan also starts working. Thank you in advance for your response ;)
  • #2 16540298
    panstalin2
    Help: 30
    Rate: 216
    Check the temperature sensor on the aluminum wire - check it with an ohmmeter, I recently replaced it and the air conditioner works.
  • #3 16540536
    miki miki
    Are you writing about a pressure sensor?
    I have the same problem - the thermostat error crashes. I am slowly running out of ideas.
  • #4 16548195
    patik1994
    Rate: 26
    Problem solved. The thermostat was to blame, after bypassing the climate started.
  • #5 16552159
    miki miki
    for me fault for the coil - too much load - bsm turned off the power
  • #6 18763708
    arturartur24
    Rate: 98
    Hello, don't post a new topic. Recently, I have a Peugeot 207 1.6 HDi 90 horses 2010. I do not want to turn on the air conditioning, after connecting to the diagbox I checked the pressure is 2.7 .... after pressing the button to turn on the climate changes in the preview that the compressor is activated but does not start
  • #7 18764009
    cisq
    Help: 8
    Rate: 48
    Check if you have a thermostat error, because without this sensor, the climate thermostat does not start, plug a 1kOhm resistor into the plug
  • #8 18764021
    arturartur24
    Rate: 98
    There are no errors on the computer .....
  • #9 18764024
    cisq
    Help: 8
    Rate: 48
    Check the engine control unit.
  • #10 18765157
    arturartur24
    Rate: 98
    The compressor can be controlled from a computer, the fans both gears the same. Standstill pressure 2.8. The air conditioning is manual and there is a mistake no communication with the automatic air conditioning controller ... I don't know if there is something mixed up with the settings in BSI Peugeot 207 1.4 VTI Air Conditioning Not Working: Thermostat Error, BSM Replacement, 2007 Model
  • #11 20645837
    jango5
    Help: 14
    Rate: 16
    Hello. I have the same - the air conditioning works?
  • #12 20676393
    th_omas
    @patik1994
    Hello, I will return to the topic ... how and where to skip it??
  • #13 20678915
    jango5
    Help: 14
    Rate: 16
    I am waiting for your reply. Thank you
  • #14 21836312
    danny0012
    >>18764021
    I have the same problem: the air conditioning stopped working after replacing the radiator or coincidence. After connecting the computer it shows error P0070: air temperature sensor. Where to look for the problem? Where is this sensor located? Is the thermostat to blame after all?
Discussion about a Peugeot 207 1.4 VTi (2007, manual A/C) with air conditioning not engaging despite correct refrigerant pressure, no obvious sensor fault, and a previously incorrect BSM module from a Peugeot 307 that was replaced. The main suspected cause was an active thermostat/temperature sensor error, with several replies stating that the climate system will not start if this sensor is faulty or missing. Suggested checks included the temperature sensor on the aluminum pipe, the pressure sensor, the engine control unit, and BSI/BSM configuration. One follow-up confirmed the issue was solved by bypassing the thermostat, after which the air conditioning started. Later posts describe similar Peugeot 207 A/C failures, including compressor command present in diagnostics but no compressor operation, fan activation, and a P0070 air temperature sensor fault.
