[Solved] Peugeot 206 1.9 Diesel 2001: Heater Blower Not Working (Gears 1-4), Resistor Replaced, Need Help
Polo_PGS 26865 7
  • #1 17473845
    Polo_PGS
    Rate: 14
    Hello, I have such a problem in my Peugeot 206 1.9 diesel 2001 r blower does not work on any gear from 1 to 4. Hot and cold air flies but does not blow what could be the reason the resistor I exchanged what next you can remove the fuse that serves from the blower or something please help
  • #2 17473870
    kamyczek
    Help: 394
    Rate: 573
    There should be control transistors on the blower, often when the motor is blurred, they burn outside the resistance.
  • #3 17473874
    Polo_PGS
    Rate: 14
    The engine blurs which whole or from the fan? You can have some photos
  • #4 17474063
    msati123
    Rate: 35
    Connect the fan briefly as you have access, you will know if it works. If so, you replaced the resistor and checked the fuses, check that the contacts in the fan switch are ok.
  • #5 17474105
    Polo_PGS
    Rate: 14
    Okay, I'll check tomorrow and let you know the fuse that is from the fan
  • #6 17474136
    msati123
    Rate: 35
    in the engine compartment, probably No. 6 or 7, 20A
  • #7 17474206
    Polo_PGS
    Rate: 14
    Thanks, I'll check back tomorrow and let you know what I have inferred. Regards
    Added after 17 [hours] 2 [minutes]:
    I connected the fan for a short time directly to the battery and it works. So what can be fuse No. 6 is kind of good and No. 7 there is nothing there please help as I saw it a fan cube one pin as if it was a bit tanned grayish with a light
    Added after 2 [hours] 47 [minutes]:
    Help
  • #8 17476794
    Polo_PGS
    Rate: 14
    Help
    Added after 15 [hours] 29 [minutes]:
    Fgswthczssvhjfddxbkhfd. Gdansk hgd
The discussion revolves around a malfunctioning heater blower in a 2001 Peugeot 206 1.9 Diesel, where the blower does not operate on gears 1-4 despite the resistor being replaced. Users suggest checking the control transistors on the blower, as they may burn out if the motor is faulty. It is recommended to connect the fan directly to the battery to verify its functionality. Additionally, the author is advised to check the fuses, specifically fuses No. 6 and 7, and inspect the contacts in the fan switch. The author confirms that the fan works when connected directly to the battery but is still seeking further assistance regarding the fuses and a potentially damaged fan connector.
