Chinese Vehicle Blackbox DVR: Connecting Red Cable in Mirror Camera - Positive (+) or Ground?
markopolo1 17118 9
Where should the red wire from the mirror camera/DVR be connected: to ground or to the positive (+) supply?
Connect the red cable to the positive (+) of the reversing bulb, not to ground [#16737462] This is the wire that should be tied into the rear light lamp/reverse-light circuit so the camera detects reverse gear and shows the parking image/guide lines on the display [#17071092]
  • #1 16737432
    markopolo1
    Hello!
    I purchased a video recorder from the Chinese Vehicle Blackbox DVR, there are no hints in the manual. I connected it properly, I ran the cable from the camera under the upholstery. Webcam works the picture shows all the time, the question of connecting a red cable, because there is only one, where to connect it to the mass or (+)?
  • #2 16737462
    Krzysztofignaczak
    Connect the red cable to the plus of the reversing bulb
  • #3 16906654
    smolki1
    Hello, I bought the same webcam. When you connect the red cab to the back, nothing has changed ??
  • #4 16906785
  • #5 16906841
    smolki1
    Super only backward on the one I'm not just going backwards
  • #6 17071092
    miron1402
    ]Hello! All you have to do is to find the cables leading to the back lamp and this red cable will be connected to the back light bulb. It works for me and on the reverse screen the parking field appears on the display.
  • #7 17604581
    zubrzyk17
    Hello, I have a camera installed in this way and the problem is that the back-up camera suddenly stops working, its lighting works and there is no picture what could have happened.
  • #8 17604589
    Krzysztof Kamienski
    Help: 2033
    Rate: 5162
    @ zubrzyk17 You've probably been at the car wash. :cry:
  • #9 17604731
    zubrzyk17
    yes I was and what can be done now
  • #10 17605021
    Krzysztof Kamienski
    Help: 2033
    Rate: 5162
    @ zubrzyk17 Buy a new camera. :cry: It is as waterproof as a pasta sieve. :cry: Unfortunately.
✨ The discussion revolves around connecting the red cable of a Chinese Vehicle Blackbox DVR camera. Users suggest connecting the red cable to the positive terminal of the reversing bulb to enable the camera's functionality. Some users report issues with the camera not working after installation, particularly after washing the car, leading to suggestions of potential water damage. The consensus is that proper connection to the reversing light is crucial for the camera to display the parking field on the screen.
