[Solved] Skoda Fabia I FL 2004 - Electric Windows Malfunction After Grommets Repair & Module Replacement
szodi 50088 8
  • #1 16551587
    szodi
    Rate: 15
    After checking all the ideas and searching the whole forum, I didn't find the answer to my strange problem.
    Skoda Fabia I 2004 The windows are not working. Electric has only front. Grommets cables repaired, grommets plugs removed and cleaned, fuses OK. As a substitute, I had a driver's window motor together with the module and a "comfort module" from under the steering wheel, unchanged.
    After unplugging and connecting the plugs from the grommet, the windows work for a while. Just remove the key from the ignition and leave for about 30 minutes, they stop working.
    If they do not work, the driver on the driver's motor window has power and weight as needed. I also checked the sensitive areas of the damaged installation under the hood just in case.
    There are also no errors anywhere related to windows or loss of CAN communication.
    Did anyone meet something like that? Thanks in advance for your help
  • #2 16551632
    spinacz
    Help: 1204
    Rate: 2654
    Check the fuse described as mirror control, this is the first fuse in the first fuse line of the fuse that starts from the center.
  • #3 16551738
    szodi
    Rate: 15
    When the windows are not working, there is voltage on it
  • #4 16551742
    spinacz
    Help: 1204
    Rate: 2654
    Something happened that the windows stopped working? Have you checked the comfort coding, door module?
  • #5 16552772
    szodi
    Rate: 15
    I don't know what caused the fault, it's the customer's car.
    I checked the coding of the door module and comfort module and everything seems ok
    In addition, after disconnecting all door plugs for a while and reconnecting, the windows work for some time.
  • #6 17749972
    krokusowa
    Rate: 77
    Did you solve the problem? I have the same situation. My hands dropped.
  • #7 17750596
    vogelek1
    Help: 36
    Rate: 114
    In the comfort module check if there is to be a plus on the red-black and red-yellow after the ignition,
  • #8 17750721
    krokusowa
    Rate: 77
    I'll check in a few days because I'm on a delegation now. Someone wrote on the forum somewhere that the 1 Poliftowa Fabia 2007 there is no connection of the windows with the comfort module, as it was in previous models.
  • #9 17763491
    krokusowa
    Rate: 77
    In my case, only the replacement of the motor with the driver helped.
The discussion revolves around a malfunction of electric windows in a 2004 Skoda Fabia I after repairs to grommets and module replacements. The user reports that the front windows work intermittently, ceasing to function after the ignition key is removed for about 30 minutes. Despite checking fuses, cleaning grommet plugs, and verifying power at the driver's window motor, the issue persists. Suggestions from other forum members include checking the fuse for mirror control, verifying comfort coding and connections in the comfort module, and ensuring proper voltage at specific terminals. One user noted that replacing the motor with the driver resolved their similar issue.
