Connecting Samsung Galaxy S5 to an Older Sharp LC-42DH77E TV: Alternatives to MHL Adapter?
boskimichal 18567 13
Can I send photos and videos from a Samsung Galaxy S5 to an older Sharp LC-42DH77E TV if MHL does not work, and what alternative device should I use?
Yes—use a Chromecast or similar Android dongle instead of MHL, since the TV output from the MHL adapter stayed incompatible on this set [#16220296] One reply also suggested looking for a dongle with Android/Kodi support [#16223883] The thread starter later confirmed that Chromecast worked exactly as wanted: image from the phone appeared on the TV, the phone controlled playback, content came over Wi‑Fi, and there was no noticeable lag during movies [#16230786] He also routed TV audio to an amplifier through the TV’s audio output, so sound played on external speakers [#16230786]
  • #1 16220160
    boskimichal
    I have a Samsung Galaxy S5 phone and a TV that is already years old and is not Smart, so the wireless connection is gone. My tv is Sharp LC-42DH77E. Is there any possibility that I can send content from the phone to the TV screen (it's mainly about photos, movies). I will add that I tried using the MHL adapter. I connect the adapter via an HDMI cable, the HDMI word on the screen replaces the MHL text, but the screen remains black and a message is displayed that the signal is incompatible. On the phone while the circle is HDMI connected / HDMIdisconected. On another Samsung TV everything works fine. Hence, I suspect that my TV does not support it, because I do not know what else I could change in the settings. What other options do I have, of course, apart from buying a new TV so that I can watch photos and videos from the phone's memory (not necessarily through mirroring)?
  • #2 16220296
    actin
    Help: 187
    Rate: 797
    Dongle tv with Android should help
  • #3 16223157
    boskimichal
    Thanks for the hint.
    This solution would allow me to resign from buying another "box", which I would not have anywhere else. Are there any WiFi problems in these devices (eg they lose their signal)? Is it possible to control them using a telephone (or only some copies allow it) and is there no conflict if in the dongle, say, is an android 4.x on a 6.x phone? When it comes to playing dongle or microSD cards, or maybe from the phone, can the device reproduce different formats? Could you recommend me maybe 2-3 devices present on the market that would work well?
  • #4 16223883
    KOCUREK1970
    Help: 3835
    Rate: 5431
    A lot of questions - no one will answer you (everything depends on the specific model, company, settings of your network, etc.) - there is no golden answer.
    What devices - every one that is within your financial capacity (the more expensive, the better it is made, the better the support, etc.).
    Look for KODI hardware on board, or give you the option of installing it.
  • #5 16228004
    boskimichal
    Ok. And assuming that I buy this type of equipment, releasing a movie (whether it is from internal memory dongle, sd card or some internet service), will I be able to let the sound on the speakers connecting the amplifier to the TV using cinch cables?
  • #6 16228070
    actin
    Help: 187
    Rate: 797
    It all depends on the device model
  • #7 16228091
    boskimichal
    What to pay attention to when buying? What should this device have in order to make what I described above possible?
  • #8 16228152
    KOCUREK1970
    Help: 3835
    Rate: 5431
    boskimichal wrote:
    connecting the amplifier to the TV with cinch cables?
    But it is not THIS device that depends - only from the amplifier (which has the INPUT ports) and from the TV itself (which has EXIT ports) audio.
    If the amplifier has only analog inputs, then the TV should have such outputs (chinch, headphone output).
    If the amplifier has some digital audio input ports (SPDiF, coaxial), then the TV should have such ports on the output.
  • #9 16228226
    boskimichal
    The amplifier is 20 kg, more than 20 years old Pioneer A-757 Mark II. The inputs have an analog course of course. But TV, which I have other than that also has such a way out. So I could cinch-cinch connect. Only, could I then mute the sound from the television speakers? Would the audio fly in parallel with TV speakers and audio equipment? If so, would not there be any shift of sound?
  • #10 16228401
    KOCUREK1970
    Help: 3835
    Rate: 5431
    It seems to me that there should be no problem - after all, it is not the headphone port, which cuts off the speakers on the TV after connecting the cable.
    There is no audio shift in the analogue.
  • #11 16228478
    kazikszach
    Help: 513
    Rate: 1100
    All you need to do is check if the TV sends a sound on this output when the source is the HDMI input.
  • #12 16228568
    boskimichal
    A lot of these unknowns. I do not know if it has a connection, but from the TV decoder the audio-video signal goes through the HDMI cable to the TV, and the decoder is connected analog to the amplifier and the sound goes correctly. Maybe the dongle will be ok. I guess I have nothing else but to decide on this and test it. Thanks for all the help.
  • #13 16229027
    kazikszach
    Help: 513
    Rate: 1100
    Try to switch cinch cables from the decoder, which goes analog signal to the amplifier to the TV output and you will see if the TV sends a signal there when you choose HDMI or the decoder as the source.
  • #14 16230786
    boskimichal
    I bought a Chromecast. Everything works the way I wanted, and even better. The sound goes to the speakers. TV has an audio output that I connected to the amplifier. I control the phone. I can transfer the image from my smartphone to the tv screen. As a result, I have access to content from the tel and the entire internet. I did not notice any lagging when displaying movies (everything is done via wi-fi). Thanks for the tips. They were helpful.
✨ The discussion revolves around connecting a Samsung Galaxy S5 to an older Sharp LC-42DH77E TV, which lacks Smart features and has compatibility issues with MHL adapters. Users suggest alternatives such as using an Android dongle for streaming content, while also addressing concerns about WiFi stability, device control via phone, and audio output options. The conversation highlights the importance of checking device specifications and compatibility, particularly regarding audio connections to an amplifier. Ultimately, one user successfully resolves their issue by purchasing a Chromecast, enabling seamless content streaming and audio output to their amplifier.
