Samsung Galaxy SM-T585 16 GB - How to connect a tablet to a TV.
zmonika 9321 3
  • #1 16859848
    zmonika
    please help. I would like to connect the Samsung Galaxy Tab A 10.1 SM-T585 tablet to the TV. I heard that you can buy such an adapter with an HDMI cable to be able to connect the tablet. The TV has no internet or wifi. I could do it with hdmi. I asked in the store about such a set, but the sellers only said that there is something like that but not every set will fit this tablet. They sold me such a set, but it did not work for this tablet - in the description it was intended to connect Samsung Galaxy phones. Do you know what set would suit this tablet and any information where you can buy such a set online?
    I would be very grateful.
    Regards
    gradek83
    Help: 930
    Rate: 2104
    Your tablet does not support MHL technology
    List of devices supporting MHL
    http://www.mhltech.org/devices.aspx
    One solution is to replace it with MHL compatible equipment or an HDMI output socket.
    If the TV has, for example, a USB socket and reads multimedia from it, then you can connect the tablet with a USB cable and the tablet can be used as a data carrier from which you can view multimedia files.
  • #3 16870223
    zmonika
    Thank you for the answer, she helped me a lot.
    Regards
    zmonika
  • #4 16913094
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    You can still use the chromecast device.
