GALAXY S7 with TV - GALAXY S7 connection with TV via bluetooth
KABAN_DG 6399 6
  • #1 16720195
    KABAN_DG
    Rate: 15
    At the beginning I do not know if a good department, so sorry in advance.
    I have a Philips 42PFL6007K12, and Galaxy S7. I wanted to connect them together (phone desktop visible on TV) to be able to watch something sometimes on TV with youtube etc.
    Galaxy S7 no longer supports MHL technology - so it falls off. The TV only supports the function with a dedicated application to control it via the phone - nothing more.
    Tell me what I would have to buy - the name of the device - to be able to connect it probably via HDMI.
    I want the transfer, if possible, to take place via bluetooth and not via Wifi because I would like to have a telephone connected to wifi.
    Of course, it's about 1080p quality :)
    when I got mixed up, please ;)
    best regards
    E8600
    Help: 529
    Rate: 2520
    For such a thing there is a Miracast function or it can be shared via DLNA but then the file must be on the phone cannot be streamed from the internet as in miracast. 1080p via bluetooth probably not only Wifi.
    By the way, the s7 top model and castrated with MHL not nice from Samsung, I have a micro HDMI port on my phone.
  • #4 16725205
    KABAN_DG
    Rate: 15
    TV miracast does not support ... I agree that previous models supported and in S7 will come up with the idea to turn it off heh
    So 1080 must go for WIFI ...
    thanks for advice
    KOCUREK1970
    Help: 3862
    Rate: 5490
    Do not expect miracles here - no one guarantees anything with wifi.
    sosarek wrote:
    Isn't it easier to buy RPi and install Kodi on it?
    You can also use any Android dongle tv.
  • #6 16758193
    KABAN_DG
    Rate: 15
    Thanks for the help.
  • #7 18190091
    andrew01
    Rate: 20
    Hi, could you write if and how did you solve your problem? I have exactly the same TV and S7 and I also regret the castration of MHL as the cable is the cable and probably no wireless casts will replace it, but I plan to buy EZcast 2 for now.
    best regards
    Andrew
The discussion revolves around connecting a Samsung Galaxy S7 smartphone to a Philips 42PFL6007K12 TV. The user seeks a solution to display the phone's screen on the TV, specifically for streaming content like YouTube. The Galaxy S7 lacks MHL support, and the TV requires a dedicated application for control. Suggestions include using Miracast or DLNA for wireless streaming, although 1080p quality is challenging to achieve via Bluetooth. Users also mention the possibility of using an Android dongle or EZcast 2 as alternatives for connectivity.
