Conversion Process: HDMI Cable to Micro USB for TV-Phone Connection Without USB Input
heszke66 10419 9
Can I convert an HDMI cable to micro USB to connect a phone to a TV that has no USB input?
No, you cannot simply convert an HDMI cable to micro USB to connect a phone to a TV. A direct HDMI→USB connection is impossible because HDMI and USB use different signal technologies [#16614340][#16614448] If your phone and TV both support MHL, use an MHL cable instead of trying to build an adapter [#16615408] Check the compatibility lists for both the phone and the TV first, then buy the MHL cable if both are supported [#16615792]
  • #1 16614326
    heszke66
    How to convert an hdmi cable to micro usb to connect the phone to the tv without usb input, is there a solution ???
  • #2 16614340
    Polon_us
    Help: 1184
    Rate: 1280
    Such a direct connection - HDMI -> USB is impossible.
    This is due to the technology of these signals.
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    Completely different technology. HDMI is used for image and sound transmission, and USB for data transmission.
  • #4 16614509
    Freddy
    Help: 1394
    Rate: 2821
    What is image and sound but data?
    Colleagues write so that you have a different goal, e.g. misleading? :)
    Many phone manufacturers allow this USB-HDMI transmission Samsung, Sony, LG, HTC, Huawei is called the MHL cable and costs about PLN 20.
  • #5 16614517
    sanfran
    Help: 963
    Rate: 3004
    But is it an ordinary cable or such a miracle as apla lighting with a scalak in the plug?
  • #6 16614544
    pepe150
    Level 36  
    Help: 288
    Rate: 943
    But my friend did not write what he wants to use. Maybe he has a GoClever phone or some other Overmax and wants to connect it to the TV. And it doesn't even have normal service support.
    In HDMI (High Definition Multimedia Interface) goes a digital signal containing image and sound data according to the standard.
    The USB standard (Universal Serial Bus) is to be responsible for data transfer.
    The entry shows that a colleague wants to make an adapter that has the right not to work on his equipment.
    I am also happy to connect my phone to the TV, but is it possible to use RS232?
  • #7 16614570
    Freddy
    Help: 1394
    Rate: 2821
    Don't mock my friend!
    At the moment, most smartphones are supported MHL and the list goes on and on.
    These are only registered manufacturers: Acer, Alcatel, Asus, Fujitsu, HTC, Huawei, ITE Tech. Inc., Kyocera, LG, Meizu, NEC, NEC Casio, Oppo, Panasonic, Pantech, Samsung, Sharp, Sony, Xiaomi, ZTE.
  • #8 16615320
    heszke66
    In general, he wants to connect the phone to the TV, but there is no usb input
  • #9 16615408
    E8600
    Help: 529
    Rate: 2520
    Making a cable is unprofitable. Make sure you have MHL on your phone and TV.
  • #10 16615792
    Freddy
    Help: 1394
    Rate: 2821
    You got a link to the list of cells, a HERE you have a link to the tv list.
    Check if your equipment is on the list, and then buy an MHL cable for less than PLN 25.
Connecting a phone to a TV using an HDMI cable directly to a micro USB is not feasible due to the differing technologies of HDMI (for audio and video transmission) and USB (for data transfer). However, many smartphones support MHL (Mobile High-Definition Link), which allows for HDMI output through a micro USB port. Users are advised to check if their devices are MHL-compatible and to purchase an MHL cable, which is typically inexpensive. A list of compatible phones and TVs can be found online to ensure proper functionality.
