Sequential Execution of Multiple Macros with Single Button: Code Guidance
zbysiomysio 7197 11
How can I run several macros one after another from a single button instead of starting them all at the same time?
Use a wrapper procedure that calls the macros one by one with the `Call` command so they execute sequentially, not simultaneously [#16202849] The thread author reports that this solved the problem [#16202849]
  • #1 16202567
    zbysiomysio
    Rate: 40
    I have several macros that are run with a button. However, I would like to be able to run all macros with one button. However, I want them not to run simultaneously, but, for example, to run Makro1, and after it Makro2, etc. What should the code look like. I tried to do something myself, but I was running all macros at the same time.
  • #2 16202569
    Freddie Chopin
    MCUs specialist
    Help: 1712
    Rate: 870
    Try pressing Alt + F4. This is of course the left Alt.
  • #3 16202665
    zbysiomysio
    Rate: 40
    Thanks for the info, but my point is to enable these macros with a button that would run the next macros and that's why I need a procedure that will run these macros one by one
  • #4 16202724
    Freddie Chopin
    MCUs specialist
    Help: 1712
    Rate: 870
    Strange - for me pressing Alt + F4 several times works, sometimes it doesn't catch the first time. Did you check?
  • #5 16202744
  • #6 16202755
    Freddie Chopin
    MCUs specialist
    Help: 1712
    Rate: 870
    Well, we don't know if the author uses Windows, because he didn't write it ...
  • #7 16202767
    zbysiomysio
    Rate: 40
    I did not check, but I mean it would work on the button, because it will not be me who will use this file. So I need the user to press the button (button) to start macros one after the other.
  • #8 16202783
    michalko12
    MCUs specialist
    Help: 462
    Rate: 321
    And what color do you have the button?
  • #9 16202796
  • #10 16202817
    Freddie Chopin
    MCUs specialist
    Help: 1712
    Rate: 870
    Piotrus_999 wrote:
    Similarly for Linux: start the terminal and enter "sudo" before the command. The rest is the same.
    It doesn't work - it asks for a password. You don't know what to enter there? The macros were supposed to work on a button, not on a password ...
    Well, finally someone asked for specifics!
  • #11 16202836
  • #12 16202849
    zbysiomysio
    Rate: 40
    I have already managed with the call command
The discussion revolves around the need to execute multiple macros sequentially with a single button press, rather than simultaneously. The user seeks guidance on how to structure the code to achieve this functionality. Initial responses included unrelated suggestions and troubleshooting tips, but the user clarified the requirement for a button-triggered sequential execution of macros. Eventually, the user indicated success with a command that allows for the desired sequential execution.
