Golf 3 1.8 90km - Gasoline Start Issues: Replaced Liquid Temp Sensor, Fuel Pump, & More
Blewik 5421 11
Why does my Golf 3 1.8 run on gas but not start on gasoline after replacing the coolant temperature sensor, fuel pump, injector, ECU, engine wiring, and fuel filter?
Most likely the gasoline injector is not getting the correct power or ground because the LPG installation cuts the injector circuit with a relay. Check the injector plug under the throttle body: it has 4 wires, with 2 for the temperature sensor and 2 for injector supply, and the injector should have a constant + from the pump relay plus ECU ground pulses when cranking [#16202980] Use a 1.2 W test bulb on the injector connector while someone cranks the engine; it should blink, and if not, check whether the missing side is the plus or the ground [#16203336][#16203577] If the injector voltage only appears when the pump runs, trace the cut wire to the LPG relay/control unit, because gas installers often break the injector feed there [#16203628] The relay may be inside the LPG controller or switchboard, but you need to locate the interrupted wire and verify where the signal disappears [#16205138]
  • #1 16202851
    Blewik
    Hello, I have a Golf 3 1.8, the car does not want to start on gasoline. Replaced the liquid temperature sensor, fuel pump, injection, on-board computer, engine harness, fuel filter, spark is there, I do not have any probe emulators and carbon and carbon simple control unit, gas works fine
  • Check injector power, ground pulses, and LPG relay wiring
    #2 16202980
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Check if the injector is receiving power.
    When you remove the dome from the throttle, you will see the injection. There are 4 wires to its plug: 2 for the temperature sensor and 2 for the injector supply.
    The injector has a constant plus from the pump relay (there is only about 2 seconds after the ignition is turned on or how the shaft is spinning) and ground pulses from the engine control unit.
    Usually, the plus line is cut by gas sellers and a relay is mounted on it, which disconnects the injector while working on LPG.
    Check what is missing.
    Enter the letter designation of the engine.
  • #3 16202986
    Pawel wawa
    Help: 1262
    Rate: 4432
    Is it possible to switch from gas to petrol, is it not working on petrol at all? Or maybe it just doesn't run on gasoline? Clarify.
  • #4 16203031
    andrzej20001
    Help: 1578
    Rate: 6669
    How do you disconnect the battery for a while it fires?
  • No LPG-to-petrol switch; battery reset ineffective
    #5 16203242
    Blewik
    grala1 can you check the power supply with a regular test tube? The point is that I do not have any gas / pb switch and it amazes me, the designation of the abs engine
    Paweł Wawa, it was impossible to switch from gas to gasoline because it went out immediately, now, when the car is standing in the garage and there is no LPG, because I stopped trying to find out what's going on with this gasoline ...
    Added after 41 [seconds]:
    andrzej 20001 does not help, disconnecting the battery for a moment, even for a few hours, does not help
  • #6 16203336
    andrzej20001
    Help: 1578
    Rate: 6669
    Remove the mushroom from the mono-injection and see if it gives the injector. You have power and impulses on the internal pins of the plug going to the injector, measure with a 1.2W bulb.
  • #7 16203535
    Blewik
    andrzej20001 should I check after ignition? or trying to start the engine? I poured 100ml of gasoline into the intake manifold and it worked on gasoline, so I will not just inject the injection because the fuel is delivered
  • #8 16203577
    grala1
    Help: 1495
    Rate: 5052
    Put a light bulb there, as a colleague wrote, and let someone spin and see if it blinks. If not, one wire from the plug to the bulb and the other to the ground and turn again, then instead of ground, it is to the plus and turns again.
  • #9 16203592
    Blewik
    ok then right now go see, it must be 1.2v? or can it be the most ordinary test tube
  • #10 16203628
    andrzej20001
    Help: 1578
    Rate: 6669
    The injector has only a voltage when it comes to the pump. If you have gas, the injector was probably cut off with the relay. Look where the wire is cut and go to the relay.
  • #11 16204638
    Blewik
    Gentlemen, the power supply is on the injection after ignition, each time it starts firing and you have to wait 30 minutes for it to be the same again. And the relay is sometimes not stag in the switchboard?
  • #12 16205138
    grala1
    Help: 1495
    Rate: 5052
    So what's missing - plus or weight?
    If you want help, write specifics, no one will drag you by the tongue.
    Maybe the relay is in the switchboard, but you did not deign to tell us what the Stag model is and what it is under the hood when it comes to LPG installations.
    If there is no plus, maybe a relay or maybe cold February on its legs.
    I doubt that there is a problem with its control, because it has power to the coil only when working on LPG.
    Instead of asking the question if the relay is in the control unit, you would have reached the injector wires. The cable from the injector must be cut and switched on by the LPG control unit, only whether the relay is inside or outside, we do not know because we have too little data.
The discussion revolves around starting issues with a Golf 3 1.8 that fails to start on gasoline despite several components being replaced, including the liquid temperature sensor, fuel pump, and injection system. Users suggest checking the injector's power supply, verifying the functionality of the LPG relay, and ensuring that the injector receives proper voltage and ground pulses. The author confirms that the car runs on gasoline when fuel is manually introduced into the intake manifold, indicating that the fuel delivery system may be compromised. Further troubleshooting involves checking the wiring and relay connections related to the LPG system, as well as the injector's operational status during ignition attempts.
