VW Golf IV 1.9 TDI 110KM AHF - Golf 4 refused to start. No fuel in the hoses
bart1500 6228 11
Why does my VW Golf IV 1.9 TDI sometimes crank but not start because the fuel hoses go dry, and where should I look for the leak?
The most likely cause is an air leak in the fuel system, especially at the injection pump, injectors, overflow/return pipes, or the fuel filter, which lets fuel drain back to the tank and leaves the hoses dry [#16536615][#16536817][#16537728][#16537748] If there is oil/fuel wetness near the pump or injector area, that strongly points to an unsealed component rather than an electronic fault [#16536615][#16537748] Check the pump for leakage first, then inspect the injector return pipes and the filter connections, because air entering there can stop the engine from starting after it sits [#16537728][#16537748] One later update also mentioned a gasket under an injector that was wet and had been replaced, which supports the injector-area leak theory [#16635812]
  • #1 16535606
    bart1500
    Help: 12
    Rate: 66
    The patient is a Golf 4 1.9 TDI 110KM AHF.
    Yesterday morning I went to the store, it fired normally. Around 3 p.m. I wanted to drive to the bank and my account. The car spins, but won't start. I went home to get my computer. Connected but no errors. I cranked it again and .. And it fired normally. I was going shopping this morning, it fired normally. I drove 100 km without any problems. I came home and I unpacked my groceries. And I fired again to rearrange the car. Everything is ok. And at 17 I wanted to move the car again. It's spinning again and won't fire. Computer - zero errors. I pick up the mask - dry hoses. Filter first thought. Well, but I didn't have a spare. I drained the old fuel from it, it was a bit of a mess. I poured oil and fired on the cake. He fired up. But I noticed something. I think it's oil near the pump. Do you think the fuel was missing, through some leak, a leak from the pump? But is it a filter?
    EDIT: Today I looked under the hood and only half of the fuel in the hose. Wanting to start the fuel from the hose, it disappeared and I don't want to start.
  • #2 16536615
    konrad_bugaj
    Rate: 57
    These pumps are unsealing. The effect after stops, depending on the unsealing of longer or shorter cars, will not ignite.
  • #3 16536762
    bart1500
    Help: 12
    Rate: 66
    Well now I see there's a little air bubble. So it gets air through a leak in the pump?
  • #4 16536817
    konrad_bugaj
    Rate: 57
    Yes. There is a different leakage on the filter.
  • #5 16536871
    bart1500
    Help: 12
    Rate: 66
    But it seems to me that it is leaking from one injection.
  • #6 16537470
    konrad_bugaj
    Rate: 57
    You need to dry it thoroughly and check it because it may be sick.
  • #7 16537553
    bart1500
    Help: 12
    Rate: 66
    Well, if the engine does not run, it is dry with the second injection. As it can be seen rope.
    Heinzek
    Help: 554
    Rate: 494
    Marecki. wrote:
    Don't listen to this nonsense. It's 100% pump-injection or dual mass.
    Troll?
    If it drips next to the injection, it can be a leak from the overflow pipes and air enters there, which causes the fuel to go to the tank.
    konrad_bugaj
    Rate: 57
    Buddy, check if there is a leak near the injector, on the transfers or from the pump, I can't see it. Let me tell you that the pump is easiest to pressurized :)
  • #10 16539276
    bart1500
    Help: 12
    Rate: 66
    The car went to the mechanic. Something mentioned that on transfers. He will put in the fuel filter from the Golf 2. And I will write the rest when I go get the car. I did not understand much on the phone.
  • #11 16635812
    bart1500
    Help: 12
    Rate: 66
    Help! Here we go again. The mechanic said nothing. He only replaced the filter on the Golf 2. Well, two months was quiet. However, yesterday it was the same again ..
    I will only add that he replaced a gasket under this injection that was wet.
  • #12 21123040
    diagautob27
    Rate: 18
    my be is hot start
The discussion revolves around a VW Golf IV 1.9 TDI 110KM AHF that intermittently fails to start, with the user noting dry fuel hoses and potential leaks. Initial troubleshooting revealed no error codes, but the presence of air bubbles suggested a leak, possibly from the fuel pump or injectors. Responses indicated that leaks could occur at the fuel filter or injector seals, leading to air entering the system and preventing fuel delivery. The user later reported that a mechanic replaced the fuel filter and a gasket under the injector, but the issue recurred after two months. The conversation highlights the importance of checking for leaks in the fuel system and ensuring proper sealing to maintain fuel pressure.
