Volkswagen Golf IV 1.6 SR 8V - Rippling speed on a cold engine.
Eltronfun 5442 5
  • #1 16290395
    Eltronfun
    Rate: 44
    Hello. Today's patient is a Volkswagen Golf IV 1.6 SR 8V with an automatic transmission. The problem relates to jumping revs on a cold engine, it also dims and you have to keep it on the gas for a while so that it does not go out. Fuel consumption is within 12l / 100km. I hooked it up today and I got the following errors:
    -17698 Engine temperature sensor - signal too small - sporadic error
    -17832 Additional air injection system 1- leakage - sporadic error
    -17549 Power calculation - improbable value - intermittent error
    -16556 System too rich (page 1) - no / not hardware related
    -Fuel level sensor range / possibilities- sporadic error
    -16556 System too rich (page 1) - intermittent error
    -17978 Control module blocked - intermittent error
    - Exhaust gas recirculation sensor - signal too small - sporadic error.
    The car has a gas installation. I would like to add that on a warm engine it also happens a little longer to turn or go out. Please help me because my hands are dropping. Thanks in advance and regards.
  • #2 16290408
    robokop
    Help: 1763
    Rate: 6371
    Left air symptoms. Often, the suction pipe between the throttle and the flow meter needs to be replaced - the vent valve in it becomes leaky. For this the plug of the liquid sensor is rotten, or the sensor itself.
  • #3 16291515
    ferguson6600
    Help: 26
    Rate: 201
    Damper cleaned?
  • #4 16291775
    Eltronfun
    Rate: 44
    I did not clean the throttle.
  • #5 16291987
    ferguson6600
    Help: 26
    Rate: 201
    Do this, just adapt afterwards.
  • #6 16662716
    dudek13
    I bet on left air. Regards, Bart.
