Golf 4 1.6sr Petrol + Gas: Engine Shaking, Power Loss, and Speedometer Issues
Mortis94 10179 2
  • #1 17570399
    Mortis94
    Hello, I have a problem with the car.
    Golf 4 1.6sr petrol + gas
    Initially, the problems only occurred on a cold engine, i.e.
    After starting, the engine shakes very much, there is no power, it seems as if it would not smoke all the pots, the problem was aggravated when the temperature drops and it rains for a long time, you smell petrol in the middle of the car and then switch the gas. the problem ceased as soon as the engine warmed up.
    I have replaced:
    Cables + candles
    Temperature sensor
    Hall sensor
    Recently, the problem has been getting worse, and the car continues to stop even when the engine is hot.
    Additionally, the speed hint goes crazy after adding gas, as in the video:
    [movie: 7ea3192d81] https://filmy.elektroda.pl/75_1542637596.mp4 [/ movie: 7ea3192d81]
    After connecting to the computer, it showed no errors.
  • #2 17570591
    M-A-T-E-U-S-Z
    Rate: 57
    Check the ignition device.
  • #3 17571005
    lukasz12345678910
    Level 30  
    Help: 173
    Rate: 488
    And where should he get the ignition device there? see if the coil is broken, replace it. That's typical of these engines. As for the speed, check the pulse generator plug on the gearbox, if it is clean, remove it and check the condition of the gears.
