Canon Pixma iP4950: Orange LED Blinks 5 Times - Printer Head Issue & Potential Solutions
Daniels111 11508 4
  • #1 16206432
    Daniels111
    Rate: 8
    I need help with a Canon Pixma iP4950 inkjet printer. The printer was used mainly for printing photos, so there is not much overprinted, max several dozen sheets. Recently, I was printing about six months ago.
    Today, after turning on the printer, the orange LED flashes 5 times. When selecting "Printer and Ink Status Information" from the Control Panel> Windows> Devices and Printers> Canon iP4900 Series, it displays information as in the attached screenshot ("Canon error.jpg").
    The manual attached to the printer says nothing about 5 flashes of the LED (attachment "Canon manual.jpg").
    According to information found on the Internet, the orange LED flashing 5 times means a problem with the head. Most of the advice is "wash the head under water". I have done it many times, because it's the 3rd Canon printer in the family, so I did it now and unfortunately it didn't help. I put on a new set of carcass (I have a few spare sets) with new chips - nothing. I reset the ink level using the button combination at startup - holding the Resume button turned on the printer, released Resume, then pressed it 2 times, the orange LED flashed, released both buttons - nothing.
    I downloaded the program "Service tool v3400" from this site:
    https://grandcousin.com/canon-pixma-ip4950-reset.html
    and I wanted to follow the instructions there, but it probably won't help, because it's about resetting the carcass level, and it seems to me that since I have chips in every set, I don't have to do it.
    Please advice if I can deal with it somehow. The printer is almost like new.
    • Canon Pixma iP4950: Orange LED Blinks 5 Times - Printer Head Issue & Potential Solutions Canon manual.jpg (68.71 KB) You must be logged in to download this attachment.
    • Canon Pixma iP4950: Orange LED Blinks 5 Times - Printer Head Issue & Potential Solutions Canon error.JPG (48.9 KB) You must be logged in to download this attachment.
  • #2 16207097
  • Running dry with a clogged head may have burned it out
    #3 16213545
    Daniels111
    Rate: 8
    I probably made the mistake of running it without ink and with a clogged head. I thought that if it had been standing and moving for 2 years earlier, now, after another six months, it will also start, and if there is no color, I will open the head and replace the carcasses. And she probably burned out.
    It pays off to buy a new head? I found the cheapest for around PLN 280. Apparently this printer is very good, they use it in photo shops. If I had a new one, I would print more often and clean this topic more often:
    https://www.elektroda.pl/rtvforum/topic2727516.html#13157452
    I also found out that there are cleaning cartridges, maybe I would start using it and the new head would last longer?
  • #4 16217374
  • #5 16262464
    Daniels111
    Rate: 8
    What happened to the WSI Servant user?
    He offered to help me repair the head so that I could send it to him, and when I did, he stopped responding to messages, and now when I wanted to write another one to him, I can see that it has been removed.
    Can someone explain it to me?
