Canon PIXMA MG3050 Lightning Triangle Blinking: Ink Change, Drivers Update, and Wi-Fi Issues
123Piotr1234 43383 4
  • #1 18219154
    123Piotr1234
    Hello! I have a problem with my printer, the lightning triangle icon keeps blinking.
    I changed the ink and nothing helps, I downloaded new drivers and still can't do anything with it. Internet connection (WI FI) did not work. Please help me quickly.
    • firefox.exe (562.53 KB) You must be logged in to download this attachment.
  • #2 18219218
    bumble
    Level 40  
    Help: 609
    Rate: 1194
    Perhaps it is blinking because there is no wifi connection. connect on the cable and see if it works.
    Added after 40 [seconds]:
    Did you connect to wifi as it writes in the manual? It was working and suddenly it stopped or how did it happen?
  • #3 18225067
    leeart
    Help: 269
    Rate: 434
    Lightning triangle - indicates malfunction or jammed paper. How many times does he blink?
    LEE-CAN SERWIS
    PLAC CZERWCA 1976R NR 2 LOK 06, Warszawa, 02-495 | Tel.: 502XXXXXX (Show) | Company Website: serwisdrukarki.pl
  • #4 18242916
    vasteq
    Rate: 184
    And it does not blink, it only shines all the time and cannot be started. No reaction. Recently, I have rarely used it because some carcasses have run out. Now I wanted to replace it with replacements (previously they were also) and here is such a zonk. Was it already over?
  • #5 18326855
    vasteq
    Rate: 184
    I understand that no one has had a similar case? Is it possible that the printer has reached the page limit and is now in the trash? Is it possible to pull out the head when the printer does not respond (the inks do not come out after opening the cover)?
