Canon Pixma IP7250 - Error 6000 - I undressed and I don't know what to look
mazbasi 17889 15
How can I fix Canon Pixma IP7250 error 6000 when there is no visible paper jam?
Error 6000 on the Pixma IP7250 is most likely caused by a dirty or damaged encoder strip or another hardware problem in the carriage/feed mechanism, not by leftover paper [#16379304][#16397017][#16401932] The encoder strip has very fine lines used to position the head and rollers, and if those markings are damaged the printer will fail, so replacement was suggested [#16401932] Cleaning it with acetone was specifically called out as bad because it can damage the strip; it should only be cleaned carefully without harming the markings [#16398461][#16399077][#16401932] The carriage should move freely to the right, and the service/cleaning module should also be checked in case it is blocking movement [#16375581][#16379304] Canon’s 6000 code was also described as a service error related to a hardware failure in the feed-roller rotation [#16379304]
  • #1 16370703
    mazbasi
    Rate: 96
    Welcome,
    I have a 6000 error in the Canon Pixma Ip7250 printer, but when I take it apart I can't see any leftover paper. I recorded a movie about how an ambulance behaves.
    [Film: 2aa96cf9c7] https://filmy.elektroda.pl/20_1490454970.mp4 [/ film: 2aa96cf9c7]
    Can you advise on what the problem is?
    Regards.
    leeart
    Help: 269
    Rate: 434
    You can see that the ambulance cannot change its position freely. Probably the cleaning module is blocking it, check it.
    LEE-CAN SERWIS
    PLAC CZERWCA 1976R NR 2 LOK 06, Warszawa, 02-495 | Tel.: 502XXXXXX (Show) | Company Website: serwisdrukarki.pl
  • #3 16378750
    mazbasi
    Rate: 96
    Thank you. Which cleaning module is it?
  • #4 16379304
    leeart
    Help: 269
    Rate: 434
    I was a bit wrong, the cleaning module is on the other side. And when you take out the carcasses, nothing lies there. Can the carriage be moved manually? Check strip encoder for dirt.
    The 6000 code indicates a service error due to a hardware failure in the printer. The failure is related to the rotation of the feed rollers.
    LEE-CAN SERWIS
  • #5 16380275
    mazbasi
    Rate: 96
    I can move it by hand without any problems and after removing the carcass there is unfortunately nothing. It was my first clue that there were scrap paper somewhere, but nothing I found. : / I can also rotate the rollers manually.
  • #6 16380553
    leeart
    Help: 269
    Rate: 434
    The correct carriage position is the right side of the printer. When you move the carriage to the right to the maximum, then how does the carriage behave, how do you turn on the printer? Is the printer main roller spinning generally?
    LEE-CAN SERWIS
  • #7 16393887
    mazbasi
    Rate: 96
    I moved the carriage maximally to the right and when the printer is turned on, the carriage goes inside and the orange LED starts blinking alternately with white and an error of 6000 appears.
    leeart
    Help: 269
    Rate: 434
    Apart from moving the ambulance, what else did you do?
    LEE-CAN SERWIS
  • #9 16398461
    mazbasi
    Rate: 96
    I cleaned it with acetone, removed some dirt, but unfortunately it did not help.
  • #10 16398926
    leeart
    Help: 269
    Rate: 434
    What did you clean with the acetone-encoder?
    LEE-CAN SERWIS
  • #11 16399077
    mazbasi
    Rate: 96
    Yes is that bad
    leeart
    Help: 269
    Rate: 434
    Very bad - I'm afraid that only the exchange is left for a new one. On each of them there are such small and thin lines, they are used to determine the location of given elements, e.g. head, rollers. If they are missing then the printer is stupid. Then clean without damaging them.
    LEE-CAN SERWIS
  • #13 16417203
    mazbasi
    Rate: 96
    Thank you for your help, so you will have to throw it in the dustbin. : /
  • #14 16417473
    leeart
    Help: 269
    Rate: 434
    Maybe buy a printer with a damaged head and change yours. Such a printer is a low purchase cost. For a few zlotys you can have a working printer.
    LEE-CAN SERWIS
  • #15 16814634
    aabgrx5
    Rate: 21
    I have the same pale. The printer was printing at a certain phase. The carriage reaches half its course and stands as if something is blocking it. And I can't figure out what's going on. Anyone can help? Two LEDs are blinking alternately or two blinks and alternating with a bright one afterwards the bright one burns for a moment and then everything from the beginning.
  • Dried black ink clogged the service station gears
    #16 20464265
    Dzida
    Help: 28
    Rate: 32
    I will describe my case with error 6000 in the Canon TS6251 printer (the construction is a bit different but very similar and the principle of operation is the same). After switching on, the ambulance drove left - right and tried to park in the service station (which you can see that it was working - it was rising, etc.) but after a while it was throwing error 6000. I dismantled the entire station and it turned out that the cause was a clog of dried black ink (pigment ), which was seeping onto the drive mechanism of the gears that move the station from the very bottom, it was not visible from above. After cleaning, lubricating and reassembling it works properly. Generally, a very tedious, difficult and long repair (the first time I disassembled the station in this model - you have to dismantle most of the printer).
The Canon Pixma IP7250 printer is experiencing a 6000 error, indicating a service error related to hardware failure, particularly involving the feed rollers. Users suggest checking the cleaning module and encoder strip for dirt or blockages. The carriage can be moved manually, but if it does not return to the correct position or if the main roller does not spin, further issues may arise. Cleaning with acetone has been advised against, as it can damage the encoder, leading to further malfunction. In some cases, users have resolved similar issues by cleaning dried ink from the drive mechanism. If repairs are unsuccessful, replacing the printer or acquiring a damaged unit for parts is recommended.
