Hyundai / i30 2008 r / hatchback - 1.6 crdi only 2800 revolutions and a speed of
Kruszon71 8820 13
Why does my 2008 Hyundai i30 1.6 CRDi only reach about 2800 rpm and 130 km/h at full throttle?
The thread points to a fuel-pressure problem that puts the engine into a limited-power mode, so it stops around 2800–3000 rpm; in the workshop the diagnostic computer showed low fuel pressure, and replacing the fuel filter only fixed it briefly before the fault returned [#16214042] Check and clean the fuel pump sump/module in the tank, because there is an additional internal sieve there, not just the external strainer [#16214406] If metal filings have entered the fuel system, the injectors and the entire system, including the tank, need to be cleaned as well [#16613376]
  • #1 16208091
    Kruszon71
    Rate: 14
    Hello (hyundai i30 2008 year 1.6 crdi
    While driving, the car works well. It reaches 2800 revolutions and 130 km / h. Pedal pushed all the way !!
  • #2 16208743
    manta
    Help: 463
    Rate: 1533
    And what next? Have you heard about the diagnosis? Codes, live data, how did the fault come about?
  • #3 16209084
    Kruszon71
    Rate: 14
    I heard it. The car goes to the diagnostician on Friday and everything will be known. My father had a similar situation in the vectra and he needed to replace the flow meter.
  • #4 16209864
    manta
    Help: 463
    Rate: 1533
    In summary, you do not know what is going on with the car, but you assume ... This type of fault can cause n-elements ... So how can you help?
  • #5 16210067
    Kruszon71
    Rate: 14
    well maybe I took it wrong.
    observations :
    I noticed it by accident, I put the gears wrong while driving, it was supposed to be high speed and it stopped at 2800 revolutions
    I stopped the car, I started it again, the problem disappeared but for a short time
    now it's only 2,800 revolutions
    the turbine works because above 2000 it turns on
    I checked the oil level is ok (it was checked 3 times)
    no warning roller is burning
    anything else should I see ??
    regards
  • #6 16210955
    manta
    Help: 463
    Rate: 1533
    If I understood correctly, did you downshift wrong? If so, check the timing immediately.
  • #7 16214042
    Kruszon71
    Rate: 14
    The car went to the workshop today:
    When the computer was connected, a low fuel pressure error occurred.
    The fuel filter has been replaced.
    After driving, the car was running normally, the speed was normal. After a while, the same problem appeared: 3000 revolutions and no more.
    after turning off the engine everything was ok and the same error again
    After connecting the computer, the fuel pressure is still low.
  • #8 16214406
    jacek074
    Level 30  
    Help: 190
    Rate: 727
    To clean the fuel pump sump in the tank, not the strainer outside, you need to disassemble the pump hopper, there is another sieve inside.
  • #9 16592574
    boniek9
    Hello, I have the same problem as in the topic, only my kia goes out. I have already replaced this filter in the dragon fuel filter 2 sensors on the rail, injectors checked and still the same too low pressure on the rail. I will add that the dragon was not very saturated at all? will anyone help?
  • #10 16595900
    boniek9
    I will add that the car stopped running at all, I think there were filings on one of the sensors because the pump was throwing, I replaced the pump, the sensor and nothing else, a disaster, thanks for your help
  • #11 16613129
    boniek9
    I can see that nobody will help?
  • #12 16613376
    marfur30
    Help: 138
    Rate: 386
    If the filings went into the system, the injectors clogged, besides the entire fuel system to be cleaned, including the tank.
    Without cleaning, even if you manage to fire up, you will not drive for a long time.
  • #13 17120459
    boniek9
    Well, the problem returned earlier, there was a broken strip, but I do not know what can break down there! and previously mentioned all the pump with a sensor injection 4 pcs 2 sensors on the strip and everything is cleaned, the filter is replaced and after 12 thousand km it is the same as it was. It's probably some bad luck !!!!!
  • #14 17138316
    boniek9
    I bought another complete strip and it is ok, but the problem is with the ignition on the cold, it does not start because 1 candle is burnt, I cannot unscrew it because it will break, and only in a week I will go to the Fachman, which I will twist even when it breaks! I start the cold one from the cake and when it was warm it was ok but today on a warm spine with 40 seconds what can be?
The discussion revolves around a 2008 Hyundai i30 1.6 CRDi experiencing a limitation in engine revolutions, capping at 2800 RPM while reaching a speed of 130 km/h despite full throttle. Initial diagnostics indicated a low fuel pressure error, leading to the replacement of the fuel filter. However, the issue persisted, prompting further investigation into the fuel pump and potential clogs in the fuel system. Participants suggested cleaning the fuel pump sump and checking for debris that could affect fuel delivery. Similar issues were reported with other vehicles, including a Kia, highlighting common problems related to fuel pressure and injector clogs.
