Hyundai i30 1.4L 109HP 2010 Timing Settings & Valve Operation Issue
AZUKS 81441 9
How do I set and verify the timing chain on a 2010 Hyundai i30 1.4 109 hp petrol engine, and what VVT/ignition advance should I see when the variable valve timing activates?
The thread did not give exact VVT advance values, but it did provide a timing diagram for the 1.4 Hyundai i30 chain setup and a separate guide for checking/adjusting valve clearances and timing. Use the posted diagram to verify the chain alignment after replacement [#14015638], and if you need step-by-step timing/valve-adjustment details, the linked foreign-language guide was suggested as a useful reference [#14166905] No one in the thread identified which camshaft carries the camshaft position sensor or explained the variable valve timing phase change in this engine.
  • Request for Hyundai i30 timing and VVT specifications
    #1 14015078
    AZUKS
    Rate: 311
    Hello. I am looking for a diagram and instructions for setting the timing in a Hyundai I 30 with a 1.4 engine, 109 HP, 2010, petrol. The car has a chain, I want to check the correctness of the settings after the recent wheel and chain replacement. Car at 2.5 thousand rotation speeds up the ignition by 20 degrees and you can hear the loud operation of the valves, Video.
    https://www.youtube.com/watch?v=Wfhyn41_94w&feature=youtu.be
    Maybe someone knows what the acceleration should be when the variable valve timing is turned on. Any information, diagrams, instructions are welcome.
  • #3 14017698
    AZUKS
    Rate: 311
    Thanks DriverMSG , the entire diagram is clear, but I have one more question about a close-up of the views marked with numbers 2 and 3 - thanks in advance.
    DriverMSG
    Help: 3984
    Rate: 4883
    I don`t have any magnification, only better quality.
    Hyundai i30 1.4L 109HP 2010 Timing Settings & Valve Operation Issue Hyundai i30 1.4L 109HP 2010 Timing Settings & Valve Operation Issue
  • #5 14018128
    AZUKS
    Rate: 311
    APPROX. Thanks for these close-ups, it helped me a lot.
  • #6 14085492
    AZUKS
    Rate: 311
    I have one more question, which camshaft has the camshaft position sensor?
    Does anyone of you have knowledge or a diagram, technological drawing of the variable valve timing gear and the details there, how the changed phases work in this car?
  • #7 14166905
    AZUKS
    Rate: 311
    If anyone wants to check the timing or adjust the valves, the link below may be helpful. You can deduce something described in a foreign language, but you always use Google.
    http://www.i30.com.ua/threads/%D0%9F%D1%80%D0%BE%D0%B2%D0%B5%D1%80%D0%BA%D0%B0-%D0% B8-%D1%80%D0%B5%D0%B3%D1%83%D0%BB%D0%B8%D1%80%D0%BE%D0%B2%D0%BA%D0%B0-%D0% B7%D0%B0%D0%B7%D0%BE%D1%80%D0%BE%D0%B2-%D0%BA%D0%BB%D0%B0%D0%BF%D0%B0%D0%BD %D0%BE%D0%B2.2482/
  • #8 15225670
    speed256
    Rate: 26
    Does anyone have the torque for the bolts in the entire engine? Shaft, bearings, oil pan or the timing cover itself?
  • #9 15225837
    witekd1
    Rate: 37
    It may come in handy
  • #10 15226272
    AZUKS
    Rate: 311
    Got a few things here as I was looking to repair mine. It`s in English, but maybe you`ll find something. If it`s not useful to you, it may be useful to someone else. Because these engines are supposedly "GOOD" and "FAILURE-FREE" :wink:
    • i30_ustawienie_rozrz__du.pdf (6.44 MB) You must be logged in to download this attachment.
    • i30-_luzy_zaworowe.pdf (2.21 MB) You must be logged in to download this attachment.
    • i30-_informacje_og__lne.pdf (857.02 KB) You must be logged in to download this attachment.
The discussion revolves around the timing settings and valve operation issues in a 2010 Hyundai i30 with a 1.4L engine (109 HP). The user seeks diagrams and instructions for verifying the timing after recent wheel and chain replacements, noting that the ignition advances by 20 degrees at 2,500 RPM, accompanied by loud valve operation. Several users provide links to diagrams and close-up images, assisting the original poster with their queries. Additional inquiries include the location of the camshaft position sensor and details about the variable valve timing gear. Users also share resources for torque specifications and repair information, emphasizing the engine's reliability.
