Fuse Replacement in Block of Flats: Comparing 20A and 25A Fuses for Apartment Electricity Safety
introder00 9927 5
  • #1 16209976
    introder00
    I live in a block of flats with two apartments on each floor. There are two counters in the corridor (one for each apartment) and two fuses
    pre-tax also one for each flat ..
    I recently broke the cork and replaced it with a new 20A. In the energy contract I have written: security. 20A, 1 phase and approx. 4 sq. M
    The old cork was 25A. Out of curiosity, I checked the cork of a neighbor who does not currently live here and has 20 A.
    A year ago they exchanged meters for new ones and it is strange that they did not notice the difference, maybe they did not even check, they sealed security ..
    I have little time because tomorrow a power fitter may come and put a seal back on me, so I want to ask what maximum fuse can I put?
    I put 20A but the question can I give 25A?
  • #2 16210008
    Wojtek 2007
    You can't - the connection conditions don't allow it.
  • #3 16210030
    zbich70
    Help: 1171
    Rate: 6666
    introder00 wrote:
    I changed for a new 20A. In the energy contract I have written: security. 20A,
    So it's supposed to be.
    Now meters are exchanged by subcontractors and they are not really interested in something for which the client does not pay them.
  • #4 16210592
    introder00
    I understand that it is more about legal issues than technical? because I went to 25A for many years and nothing happened
    I still have a question, since I have 20A before the meter, the sum of all fuses in the apartment cannot exceed 20A?
    At the moment I have three: contacts 16A, Light 10A, bathroom 16A which together gives 42A
  • #5 16210679
    mar_uda
    Help: 63
    Rate: 158
    But you probably do not connect bulbs with a total power of 2.3kW. Fuses are used to protect cables and other installations. At least in normal countries, because in Poland counter-counters are also used as power limiters.
    It remains to get used to it. Or ask for more power allocation and upgrade your downstream installation if required.
  • #6 16210729
    Brivido
    Help: 226
    Rate: 430
    OK"
