VW Touran 2.0 TDi 2005 - Front Wipers Not Working, Rear Wiper Functional, No VCDS Errors
kubuswujo 30735 4
  • Seeking front wiper diagnostic steps and VCDS test
    #1 16213018
    kubuswujo
    Rate: 71
    Hey!!
    I have a problem with mine Touran 2.0 TDi 2005
    And so:
    I do not have any wipers at the front and I do not know what may be the reason, the rear wiper switches on normally and goes.
    I checked the fuses and they are all ok, but I do not know which one is from the wipers, so maybe some is missing
    (there are many empty seats in the engine compartment).
    I connected the car under VCDS but this one does not give any errors related to wipers ....
    Where should I start to look for the cause ?? And how to search?
    From what comes to my head quickly:
    fuses
    broken wire
    wiper motor from the front (how to get there?)
    Damaged handle.
    From what to start, because maybe you had a similar problem?
    Thanks in advance!
    Cuba
    edit:
    Will I do a wiper test for VCDS ??
    Then if they walk, I know that the handle or wires are broken.
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    The mask opening sensor is functional?
    Are they not working while driving?
  • #3 16213069
    kubuswujo
    Rate: 71
    I have not checked the mask opening sensor, so they do not work ...
  • #4 16213085
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    See in the plug from motors whether there is power and mass.
  • #5 16223717
    kubuswujo
    Rate: 71
    It turned out that the problem was not a tapped mask sensor, thank you for the answer because I would not have it. :)
