VW Golf V 1.9tdi 2005: Wipers and Washers Not Functioning While Car is Stationary
karolk123321 6321 2
  • #1 16521123
    karolk123321
    Hello, as in the subject, recently after replacing the master cylinder I have a problem with wipers and washers.
    It is about the VW Golf V 1.9tdi 105koni from 2005.
    Namely, I can not turn on the wipers at a standstill, but when I drive they work normally, but the windshield washers do not work, I thought it was the washer pump because the rear ones normally operate as a wiper and washer.
    After replacing the washer pump, the same problem persists.
    I will add that the mask light is not illuminated that it is open.
    The car was also connected to the computer and shows that the stop switch turns on the wipers and they do not walk
  • #2 16521338
    damdam
    Help: 274
    Rate: 950
    and when you open the mask it shows that open?
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #3 16521448
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    karolk123321 wrote:
    The car was also connected to a computer and shows that the handle turns on the wipers
    Is the mask sealed by the computer?
